Reply 80 of 1037, by elianda
Edit: I got the remote debugger going.
It basically freezes as well. I can not run single step as this would require the original source project.
Youtube Channel
Reply 81 of 1037, by red-ray
Good, put the attached SIV 5.41 Beta-22 .PDB file in the same location as SIV32L.exe on local system.
Try putting breakpoints on cpu_setup_other() + cpu_get_maker() + cpu_is_cyrix() + cpu_cyx_read(). To look at the CPU block set a watch on smg->cpu.
    16.61 KiB
    MSVC 6 Setup
Reply 82 of 1037, by red-ray
GigAHerZ wrote:
red-ray wrote:
GigAHerZ wrote:
Did one more run with the 486DLC-40. Not exactly right...
Thank you, so the Cyrix detect code must need adjusting. Please post the Menu->Hardware->CPUID->CPU-0 screen or the save file from doing Menu->File->Save Local.
There you go!
Thank you, but the text is truncated and I can't read the last number, press [Copy], paste the text into notepad and post the text please.
Reply 83 of 1037, by GigAHerZ
There you go!
    486dlc_cpu.txt
    1.21 KiB
    53 downloads
Reply 84 of 1037, by red-ray
GigAHerZ wrote:
There you go!
Thank you, I pasted the text into a SIV save file, recreated the issue and expect I have fixed it. In test mode I get as below.
The issue was triggered by Cyrix DIR0 being 23 when the datasheet says it should be 03 😕 I have attached SIV32L 5.41 DLC2-23 please replace Beta-22 with it and let me know how it does.
DLC2-23 should also get the speed correct, out or interest what does Menu->Help->Conversions->CPU MHz report?
Regards, Ray
file.php?id=67741
    71.09 KiB
    SIV running is test mode
Reply 85 of 1037, by elianda
So just debugging with the PDB file is less helpful than thought.
I wanted to execute to the location where the string "Process No CPUID Instruction" is written to the console, but one can not search in the disassembly window. It is the last string written to the log before it freezes.
Every reboot into windows on the 386 takes 3+ minutes and I already had to reset the machine a lot. When it freezes the remote debugger is not helpful at all as it thinks the process is currently in a system call and waits.
Can you give me a memory location relative to the entry point where "Process No CPUID Instruction" is written? It would be a good start.
Youtube Channel
Reply 86 of 1037, by red-ray
not really as it will be different on your W95 system to any system I have. Looking at the code it's as below, so put a breakpoint on cpu_setup_other()
Reply 87 of 1037, by GigAHerZ
Close enough! (Y)
Gonna switch back to 386. Will make a run with that as well for fun. 😀
    13.61 KiB
Reply 88 of 1037, by elianda
Once again, without a .c source file the Debugger shows Disassembly ONLY. The PDB file only resolves symbol names in the Disassembly. The Disassembly can not be searched for symbol names in VC6 the only thing I can do is manually scroll and look what it shows.
I do not see any C code or C structures where I can set break points.
Due to the size of the program it is basically impossible to find the call to cpu_setup_other() manually by scrolling through the disassembly.
Youtube Channel
Reply 89 of 1037, by GigAHerZ
Unfortunately the siv can't load up it's ui on 386dx. It hangs the whole computer.
But before it does, it is able to generate the log file, so there you go.
    siv_dbgout.log
    2.67 KiB
    54 downloads
Reply 90 of 1037, by red-ray
Thank you for youe testing on the486DLC2 and the 386DX report, elianda sees the same issue and we are trying to figure out why.
At lest SIV now get's the 486DLC2 correct. Compared to the 386DX issue that was trivial to fix 😁 .
The good news is that given SIV runs OK with the 486DLC2 CPU in the same system then it must be something about 386 CPUs that causes the issue, if only I had one here....
Can't you do as below?
    11.06 KiB
    MSVC 6 setup
Reply 91 of 1037, by DosFreak
Obviously real hardware would be prefered but would it be useful to load up 95 on a 386 using pcem to troubleshoot the issue?
Make your games work offline
Reply 92 of 1037, by red-ray
I have just uploaded SIV 5.41 Beta-23 which should be OK on your Intel 386DX, is it?
The lockup was happening in the code that measured the CPU speed so for Beta-23 this is not used and no speed will be reported.
I have found and fixed the root cause of the issue and SIV 5.41 Beta-24 should now report your Intel 386DX speed, does it?
Thank you for the thought, but I suspect this would not help. We found that the issue is within the CPU speed measuring code that is used on CPUs that don't have TSC support.
GigAHerZ tested Cyrex486DLC2 (OK) and Intel i386DX (Has issue) CPUs iusing the same motherboard, neither have TSC support so I suspect it's down to a timing issue which is unlikely to show up in in a VM.
Reply 93 of 1037, by red-ray
Again thank you for all your help in tracking down this issue. I hope that what you have learnt about MSVC 6 remote debugging will be useful. BTW the output from such as -DBGINI should be output to the MSVC output window rather than a file, is it?
I think I have found out what went worky and fixed it. Would you try a test SIV on your i386 please?
Reply 94 of 1037, by elianda
I can do that. The previous version is currently still running in the benchmark loop...
Youtube Channel
Reply 95 of 1037, by red-ray
Great, I sent it via Skype, is it stuck again? I think it will loop 2^32 times so will about 28 days to finish 😳
Reply 96 of 1037, by feipoa
SIV32O beta24 on NT 3.51 running NexGen PF110. CPU Speed displays correctly!
    SIV_NEXGEN-NT351-B24.zip
    92.88 KiB
    61 downloads
    SIV_DBGOUT.log
    5.01 KiB
    51 downloads
    20.08 KiB
Reply 97 of 1037, by red-ray
feipoa wrote:
SIV32O 5.41 Beta-24 on NT 3.51 running NexGen PF110. CPU Speed displays correctly!
Thank you for testing the beta and posting the results, all the tricky bits worked ideally. The only issue was that for CPUID 1 your CPU returned 00000504 when I was expecting 000005FF which is what elianda's Nx586-P90 returns.
Comparted to the first run SIV found the name from the BIOS along with the version and date, is AMI NXPCI W.05.09 10/10/94 what the system reports when it posts? SIV also found the Matrox Millennium G200 SD PCI and reported it's clocks. I have adjusted Beta-25 to allow for the model being 0 rather than 15 and will release it in a while. I can't do much more 'till I get the Nexgen 82C500/1 Nx586 Chipset - Vendor ID 1074-4E78 datasheet.
Below you can see below from Beta-24 SIV works OK on an i386, but SIV took about 41 seconds to start-up! It would be good if you tried it on your SXL2-66. It's a shame NT4 won't play, maybe a clean install would. If you don't have NT then SIV should do OK on W9x.
If NT4 won't then I would hope NT 3.51 would. BTW which shell do you have on your NT 3.51 systems? If it's not the "New Shell" if you switch then the SIV32L screens may be OK. I also find it much easier to use as it's much the same as NT4/W9x and such as Right/Click are supported.
file.php?id=67833&mode=view
    946.42 KiB
    SIV worked OK on an i386
Reply 99 of 1037, by red-ray
feipoa wrote:
There is an NT 4.00 shell for NT 3.51? Where do I get this?
Basically yes, see https://www.google.com/search?q=NT+3.51+newshell. I recall once installed it reports NT 4.00 rather than NT 3.51 so I needed to adjust the SIV start-up for this. As to where it came from I can't remember, I suspect I found it on one of my MSDN CDs when I added NT 3.51 support in SIV 4.45 released on 14-May-2014. The easy option is for you to use the attached, see the .WRI wordpad files for how to install it.
I just spotted I have some NT 3.51 Matrox G200 drivers which came from http://ps-2.kev009.com/pcpartnerinfo/ctstips/cf6a.htm
Below shows how SIV decides what to do, note how the NT 3.5x kernel can have the NT 4.0 GUI 😲
BTW do you run NT 3.51 on any other systems?
    if( smb->win_bld > 1060 )                                                   // >= NT 4.00 Kernel ?
smb->drv_nam = TEXT( "SIVNT4.sys" ); //
else //
if( smb->win_bld > 600 ) // >= NT 3.5n Kernel ?
smb->drv_nam = TEXT( "SIVNT3.sys" ); //
if( WIN_MAJ < 4 ) // NT 4.00 GUI ?
look &= ~( LOOK_ICON ); // no, there is no Icon Tray
else // == NT 3.10 Kernel
smb->drv_nam = TEXT( "SIVNT1.sys" ); //
look &= ~( LOOK_OTT | LOOK_ICON ); // remove Only allow True Type fonts + Icon Tray
    newshell2.zip
    2.04 MiB
    52 downloads
    NT 4.00 shell for 3.51 SP5
