First post, by data9791
Been wanting to build a high end Win98 gaming rig for a while now. Was recently gifted an Asus A7N8X motherboard along with an Athlon XP 2800+ CPU (AXDA2800DKV4D) and 512mb Geil PC3200 DDR400 RAM. The motherboard uses the nForce chipset and appears to have Win98 Driver support, but I am dubious as to how well it would work. I also have the opportunity to pick up a BFG Geforce 6800 OC 128MB for basically free. From what I understand this card quite potent for 98 era games and has decent driver support for the OS. Will this CPU and GPU pair without major bottlenecks? Is there any advice you can give me? I understand this hardware is a bit out of the ideal time period for Win98, but money is very tight and I'd very much like to make this work if possible as it will represent almost no money out of pocket. Below are specs links:
Motherboard
https://dlcdnets.asus.com/pub/ASUS/mb/socka/n … e1859_a7n8x.pdf
CPU
http://www.cpu-world.com/CPUs/K7/AMD-Athlon%2 … A2800DKV4D.html
RAM
https://www.memoryc.com/3659-512mb-geil-pc320 … 3-6-module.html
GPU
https://bjorn3d.com/2004/09/bfg-geforce-6800-oc-128mb/
Reply 1 of 5, by dionb
My housemate ran Win98 on that mother board (well, the A7N8X-E Deluxe to be precise) with 512MB RAM back when that hw was new. Don't remember the GPU, but it was nVidia AGP too. Biggest problem was hardware: that Asus board was impossibly choosy with RAM, only ram stable with some Infineon DIMMs I had on my Gigabyte GA-7NF400L (same chipset), whereas all his DIMMs (he tried several sets) worked fine on mine. We swapped 😉
Be prepared to try multiple DIMMs before it works properly. Follow Asus' QVL for the board (the exact revision of the board!) if at all possible.
Also note the nForce2 supported dual-channel DDR, so you get significantly better performance with 2x256MB than with 1x512MB. That said, if the 512MB DIMM works and you don't have spares or money to buy more, just use it - you'll lose about 20% of performance but it should be fully functional and stable.
Reply 2 of 5, by The Serpent Rider
No.
Also not true.
Reply 3 of 5, by dionb
No.
Yes.
http://ixbtlabs.com/articles2/nforce2-1vs2cha … nels/index.html
Dual-channel mode vs. single-channel mode, % difference With the external video card (GF4Ti4600) With the integrated graphics […]
Dual-channel mode vs. single-channel mode, % difference With the external video card (GF4Ti4600) With the integrated graphics core (IGP)
memory reading +0.4 +4.4
memory recording +2.3 +15.5
memory copying +20.9 +31.5
MPEG4 +2.2 +6.7
WinAce +2.9 +8.4
drv-08 +24.7 +55.0
dx-07 +15.9 +65.8
3dsmax-01 +1.8 +13.5
light-05 +4.6 +45.0
proe-01 +19.0 +24.6
3DMark2001 +1.7 +65.0
RtCW(Fast) +3.5 +42.4
RtCW(High) +1.1 +76.1
SS2(Speed) +2.8 +40.6
SS2(Normal) +1.8 +67.1
Exact gain depends on the application, but in every single benchmark using dual channel scores better. Note that the discrete GPU scores here use a far slower GeForce4 MX 440 than the 6800, so would stress the AGP bus and so memory controller less. With a 6800 the difference will be somewhat higher, although that difference is not likely to be significant.
Reply 4 of 5, by The Serpent Rider
For roughly 2-4%, yes. And let's not even mention IGP scores, because it's silly. My statement remains correct: there's no significant improvement with dual channel enabled.
