First post, by kwyjibo
Greetings to all,
I am looking for information about existing computers from the big companies that were equipped with dual socket 5/7 and that its intended use was as a personal computer or workstation and not a server (I know that the difference can be subtle even more at that time).
Can you add more models to the list?
  • HP Vectra XU 5/XXXc (desktop)
  • Dell OptiPlex DGX 5100 (desktop)
  • Intergraph TD-30 (desktop)
  • Digital Celebris XL 5xxx
Here is a list of server to keep them apart:
  • NEC ProServa V Plus / Zenith Z-Server WL
  • Digital Prioris XL Server 5133 (this is (maybe) a Celebris under another model name or the other way around)
Edit: Added a few models, changed socket to s5/7.
Reply 1 of 5, by red-ray
Gigabyte GA-586DX, see https://www.gigabyte.com/Motherboard/GA-586DX … #support-manual
Reply 3 of 5, by H3nrik V!
I have a couple of Dell Precision 420's with cpu on daughter board. And AFAIK, there exists dual daughter boards for this machine ..
EDIT: Sorry, the Precision 420 was dual PIII.
The machines with daughter boards were Compaq ProLiant 1500
Reply 4 of 5, by Standard Def Steve
I have an old Vtech machine with dual P60s. It’s been a while since I’ve fired that thing up or had it open. IIRC both sockets are on a daughterboard, and the motherboard not only supports the dual Pentium board, but also a dual 486 card. I think. Will take a closer look at it later on.
Ten Gigahertz
5 Groovy GHz: Ryzen 9 5900X | GTX 1080 Ti | 64GB DDR4-3600 | 2TB NVMe, 8TB HDD | Win 10
5 Troll GHz: AMD FX-8350 | Radeon R9 Fury | 16GB DDR3-1866 | 500GB SSD, 2TB HDD | Win 8.1
Reply 5 of 5, by eisapc
While I own multiple dual PPro desktop systems I never came across a dual socket 5/7 Desktop.
Most dual socket 5/7 systems I know/own are in the server category
Compaq Proliant 1500 with Dual CPU processor board
Compaq Proliant 2000/4000/4500 up to 4 CPU boards with Socket 4 or 5
IBM Server 320 MCA/PCI and EISA/PC versions were availiable
hp netserver LH pro
SNI PCD 5T
As statet before there are several boards made by ASUS or Gigabyte.
