First post, by Fläskboi
Hello folks,
Anyone having the latest BIOS update files or know where to download them? I'm stuck with an almost unbootable system after updating 1/2/1999 to 8/11/2000 version 🙁
It's the 1MB ROM version.
Reply 1 of 11, by Warlord
wims bios has these versions
You could always roll back to 1999 version
Epox EP-MVP3G-M VIA Apollo (M)VP3 2A5LEPA1 12/21/2000-MVP3-596-W877-2A5LEPAEC-00
Epox EP-MVP3G-M VIA Apollo (M)VP3 2A5LEPAE 2A5LEPAEC-00
Epox EP-MVP3G-M VIA Apollo (M)VP3 2A5LEPAD 07/06/1999-MVP3-596-W877-2A5LEPADC-00
Reply 2 of 11, by Fläskboi
Warlord wrote:
wims bios has these versions […]
Yeah, but sadly registration is needed... for a fee 😒
Reply 3 of 11, by Repo Man11
The one available on Jan Steunebrink's site say that you need to upgrade to a 2 megabit BIOS chip to use it - maybe that's your best bet at this point?
Reply 4 of 11, by Fläskboi
Would love to! Just don't know how to tease Epox out of its grave so I can purchase the 2MB chip.. 🙁
It seriously worked excellent until this stupid up(down-)grade, because I somehow felt a 3GB drive wasn't enough. Now it's unrestartable without boot loops, it's colliding IRQ's with one VxD error after another (OK, it's 98SE, but still), unexpectedly loses FDD, CD-ROM and USB connection, and so on. Curiosity's stalking if this BIOS is right at all.
Reply 5 of 11, by ShovelKnight
Any 2Mbit chip should do, e.g. SST39SF020A (available new from Mouser). But it's possible you would have to flash it in an external flash programmer, e.g. TL866.
Reply 6 of 11, by meljor
My board already has the 2mbit rom so that's too bad. I do however also have the Epox mvp3c-m and that one has the 1mbit rom. I know some of these boards carry the same bios file, maybe this one might work? I can make a backup with a programmer if you want it.
EDIT: Sorry, I see now that this bios is differnet (on the steunebrink site)
Reply 7 of 11, by meljor
According to the text file this should be the 1mbit version of 16-7-1999. Hope it helps. Comes from: https://www.infania.net/misc/moboarchive/Epox … bios/index.html
    mvp39716.exe
    162.89 KiB
    73 downloads
Reply 8 of 11, by cyclone3d
Found it available on the archived Taiwan EPOX page:
http://web.archive.org/web/20030627052258/htt … _cate=07_fae_03
Already verified that the files are downloadable.
Attaching just in case - dates were ones listed on the site:
1Mb:
MVP30811.ZIP
129.38 KiB
66 downloads
(Last Version) September 9, 2002 (looks like it is really August 11, 2000)
MVP39825.ZIP
129.27 KiB
60 downloads
(Solve the problem that Linux cannot be shut down / Solve the Y2K problem) September 3, 2002 (looks like August 25, 1999)
From Chinese site:
http://web.archive.org/web/20000620164156/htt … om.cn/index.htm
MVP39811.zip
110.13 KiB
53 downloads
(Solving Linux shutdown problems) August 20, 1999
mvp39706.zip
110.14 KiB
54 downloads
(July 6, 1999)
1. Support ECC error display function
2. Fix Linux system problems
3. Support SB Link
4. Solve EON Permedia 2 AGP Card compatibility issues
5. Improve the performance of the IDE interface (VT82C596 CE Version)
From Taiwan Site
2Mb:
VP3C0C21.ZIP
143.78 KiB
60 downloads
(Added support for EON Flash ROM / This version of BIOS should not be used on the EP-58MVP3C-M motherboard) August 21, 2002
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 11, by Fläskboi
cyclone3d wrote:
Found it available on the archived Taiwan EPOX page: http://web.archive.org/web/20030627052258/htt … _cate=07_fae_03 […]
1Mb:
MVP30811.ZIP
MVP39825.ZIP
From Chinese site:
MVP39811.zip
mvp39706.zip
(July 6, 1999)
3. Support SB Link
From Taiwan Site
2Mb:
VP3C0C21.ZIP
Wow, many thanks for the links there mate! Actually tried the archive of the official epox site, pointing only to 302 errors. Definitely gonna give it a shot when the board is set up again (spent the night replacing it with a P5A; a good advice for solving endless incompatibility with the Matrox G400 AGP).
Reply 10 of 11, by BenM
Back in the day I was the person who discovered that the 2Mb bios chip was required to support the K6+ CPUs on the MVP3G-M. Notes on Jan Steunebrink's web page were provided by me. 😎
The original release of the board only had a 1Mb bios chip. A hardware revision released a board with a 2Mb chip. When the K6+ CPU arrived I was disappointed that the CPU didnt work with the latest 1M bios at the time. I was able to get a 2Mb chip off the distributor and flashed it up using VP3C0C21.ZIP and the CPU overclocked like a dream and ran stable as.
Reply 11 of 11, by perhenden
About the bios chip. Mine came with a Winbond W29C020-12 2Mbit chip. This may be the "original", that Epox supplied. If not, it is at least compatible with this motherboard.
