Reply 80 of 389, by DenizOezmen
Nemo1985 wrote on 2022-02-16, 10:03:I can confirm that the rpm issue is solved on the CUBX
Very good, thank you!
Nemo1985 wrote on 2022-02-16, 10:03:I also tested the via C3 cpus I have (just 2 unlucky: a C3 800 rated for v1.25 800 mhz which seems a Nehemiah cpu despite it should start from 1ghz and the 1.2 ghz cpu v1.45):
The first one isn't detected, debug card shows the infamous ----
It's likely that the power controller on the board only goes down to 1.3 V. If the CPU really requests 1.25 V via its VID pins, the controller will disable its outputs.
Nemo1985 wrote on 2022-02-16, 10:03:while the second is able to boot but there are 2 quirks: it gets identified as pentium 3 from the bios and despite I change the voltage setting in the bios it always provide v1.5 (I tried to go down to 1.3)
Are you sure the voltage does not get applied correctly? The HW Monitor output can be misleading, see this post for details.
Nemo1985 wrote on 2022-02-16, 10:03:Is there a chance to fix those issues? I will gladly do any testing if needed.
Well, it depends on how deep this rabbit hole turns out to be. 😉 If it's more or less about the cosmetics, it should be feasible. Please check out the attached BIOS.
[Edit: removed obsolete attachment]
