IBM Aptiva
First post, by boygrunge
Hi all,
yesterday I found my old Aptiva 2144-743 (Italian market) in my parents' house, it was in a box, with the Recovery disks.
I reconnected it and it seems to be working. It has correct date and time, RAM is correctly detect, floppy is working, the hard disk is gone 🙁
I have a DOM, 256MB (the Aptiva was born with 170MB hard disk), on which I restored the original software, but after the boot I see the prompt blinking and everything freezes.
I have some quesitons for you:
1. do you think that the DOM - connected directly to the IDE connector on motherboard - could have some issues to allow the OS to start?
2. do you think that with a CF-to-IDE adapter and a CF with 8GB it should work better?
3. where can I find the last BIOS released for this machine? When I used it (from 1994 to 1999) I was not so trained on keeping update PCs
Thank to all for all the answers! 😀
Reply 1 of 2, by Horun
I do not know about your DOM or if a CF to IDE will work.
This page talks about the last BIOS for Aptiva 2144 and 2168: http://ps-2.kev009.com/pcpartnerinfo/ctstips/f47a.htm
and if you look for odyflash you can download the text and bios here (scroll down and get odyflash.exe and odyflash.txt)
http://john.ccac.rwth-aachen.de:8000/ftp/mirr … /pccbbs/aptiva/
Reply 2 of 2, by boygrunge
Horun wrote:
I do not know about your DOM or if a CF to IDE will work. This page talks about the last BIOS for Aptiva 2144 and 2168: http://p […]
thanks a lot, I'll give a look! 😀
