Predator99 wrote:What do you think how many combinations I tested before decoding the jumpers on my cards? Not 2^48. Maybe 20. Other people also did it that way. If you like to do it different or keep searching for the manual - good luck.
Frankly speaking, when reading what you did so far I have not the impression you know what you are doing and where the problem is...
There are 48 switches. That's where 2^48 comes from. I do not want to sit and play with switches the rest of my natural lifetime. If there is no documentation, I cannot just set them outright to be the correct pattern.
There is a bank of 8 switches labelled "mode." The card currently does absolutely nothing when installed in the machine it is to go into. That means that if it is not this combination, then it must be one of the other 255 combinations for the mode switch. That, or it could be one of the three cryptic jumpers. Or it could be any amount of the switches labeled "Bank" - Of which there are 40 to set.
Because I do not have a manual or any other information on this board, I am going to have to go through other combinations until I find one that works - The only jumper I can be sure is set right is the wait state jumper.
Because there are 48 switches with two positions each, that brings us to a total of 2^48 combinations possible across all 6 banks of switches. Again, this does not include either of the 4 position jumpers, nor the 3 pin jumper at the bottom of the board.
Claiming I do not know what I am doing is incredibly rude when I'm telling you I am not going to spend the next few weeks flipping switches on this card blindly until something happens. I have also already read the information you linked me to and I have also already made an attempt at this method
The thread you linked - Which I had already read before posting this thread, mind you - Is people blindly flipping switches because they cannot find manuals or other documentation for their boards. There is some method to it, I admit, as they can watch the memory window move in testx - but nothing appears in my XMS space with this board installed as it is.
Again, it does not backfill conventional memory. It does not map to UMBs. It is not detected by a generic EMS driver. The machine does not recognize any XMS memory, and an XMS viewer I have already tried does not show any memory in the XMS address space. This means that, in it's current configuration, this card is not functional at all. The method described in the thread relies on some kind of working configuration to be able to see the memory in the XMS address space and simply shift it until it is in a sensible position - This card is not showing up. Period. Which means I'm going to have to at least change the mode switches or one of those three jumpers. There are 255 more combinations of switch positions for the mode switch alone.
Do not be rude when you cannot (or simply will not) read the information I have already provided.
