First post, by justajeffy
I've got this HP Vectra VL that I'm trying to figure out how to open up. As far as I understand, step 1 is removing the front panel by unlocking the 2 clips on the bottom of the case. I can't seem to get them into the open position. I suspect that the clips might be installed incorrectly. Does anybody here have a similar machine they might be able to check if the clips look like mine?
Here's a view of the bottom of the case with the front facing to the left.
(click for full size)
Reply 1 of 9, by Horun
Sorry no but did you read the manual, specifically: https://www.manualslib.com/manual/276849/Hp-V … ?page=29#manual
It would help if you showed a picture of the front of the case because diff models had diff cases....
Reply 2 of 9, by Intel486dx33
It the keylock locked ?
Unlocking the two front tabs should allow the cover to slide off.
Reply 3 of 9, by Deksor
Yeah you have to pull the cover from the front. If it's stuck the key lock is probably set. You should be able to force it though but I don't remember how (I think the youtuber uxwbill made a video about this)
Reply 4 of 9, by justajeffy
It's a Vectra VL5/200. I found the manual online here: http://pdfstream.manualsonline.com/b/bd541704 … 8fc3394997d.pdf
Page 19 describes how to open the case.
I'm still thinking the issue is that the clips are installed incorrectly. They move, but seem to be blocked by the chassis which prevents fully unlocking. You can see what I mean:
Trying to figure out how to get it unlocked without breaking the plastic...
Reply 6 of 9, by oeuvre
Nope, that's the correct way. Slide them both towards the middle and then puil the case towards you away from the rear of the machine.
Reply 7 of 9, by SSTV2
Clip in the first picture is unlocked and in the beginning of the GIF it's in locked position. Pull the case cover outwards, it will slide by about 3 centimeters, then just lift it up.
Reply 8 of 9, by justajeffy
Got it. I'm a goof. I guess I was just being too delicate with it. Gave it another try and was able to slide the top of the case forward and lift it off.
Thanks everyone!
Reply 9 of 9, by oeuvre
aww yis
