First post, by lowlytech
I have a trident VLB card.., i know 🙁 Looking to upgrade the memory on it and I thought the board had 512kb of VRAM, but now I am starting to doubt myself and think it has 1MB onboard. So I guess an upgrade would get it to 2MB if this was the case. Can anyone confirm how much VRAM is currently on the card and what chips I would need to bump it up. The card currently has 8 chips "tms44c256dj"
This is the link I am thinking that is the correct memory, basically 2 of these would make 1MB, correct??
Thanks..
354.18 KiB
Reply 1 of 4, by Tiido
Those memory chips should work perfectly, just pay attention to Pin1 on both socket and the chip or there will be destruction.
Reply 2 of 4, by derSammler
One edge of these chips is always angular so normally you can't insert them the wrong way - they won't fit into the socket.
Reply 3 of 4, by Tiido
That is true on PLCC chips but SOJ are perfectly symmetrical and there's nothing stopping you from inserting them the wrong way. I have seen plenty of burned sockets and memory chips, all from someone inserting the chip wrong way.
Reply 4 of 4, by lowlytech
Thanks Tiido, got the chips on the way. Thanks for the orientation reminder as well. Will make sure I don't schrute it and put the chips in backward.
