First post, by parhelia512
Hello everybody 😀
I bought a MSI MS-6168 ver2 which was in a really bad shape. Lot of dust, bad capacitors, missing inductance and maybe more that i can't detect.
My electronic knowledges are really poor (absent ?) and i would like to rebirth this board.
- For capacitors replacement, i think my job is OK : Same specifications...should be ok.
- For the two inductances, i tried to find visual approaching ones (yes this is not really science ! 😊 )
I gave it a try and...The board is powering on but nothing else.
In fact, the strange thing is that the motherboard wake up 3 to 4 seconds after shorting the good pins...strange.
All MOFSETS seems to report a correct voltage (thanks Shamino to tell me how to do this! ) but the MOFSET that is near the memory slot is reporting 1.6V (which, if this is the one for the memory is too low).
Here are the pictures of the card. There is a small scratch on the top back...don't know if a track is affected.
I would enjoy to listen your comments on how can i do to rebirth this little board !
Thanks 😀
