First post, by plussken
Hi guys
Have a quite uncommon (?) issue with powering new old md. Assembled a pc with bare minimal hardware:
- 4core dual – status unknown, have some scratches,capacitors looks good socket pins seems to be OK
Q6700 – in working condition
PSU 1 – same
PSU 2 – same
DDR 2x1gb – same
IDE CD-ROM - probably OK
AGP – same
Switched 24 pin connector to 20 mb connector, 12V 4 pin connector, PC speaker, power and reset button. Powered on. My PSU and CPU fans started immediately after I plugged PSU to wall. No beeps, no video, no reaction to power and reset buttons. Reconnected everything and switchrd another PSU and have the same issue. I thought that mb probably experienced some shorts in case and put everything out and re-assembled at anti-static carpet. At this moment neither PSU nor CPU fans would spin. Put another PSU and have same results - system seems to be dead. Put everything back to case - nothing. Clear CMOS - nothing
My googling skills probably as same shitty quality as assembling PC, yet I found nothing that could explain such issue.
What was it? Did I effectively burn my mb?
