First post, by athlon-power
When I first got that 486, I had two things in mind that I knew I immediately needed to get for it: cache, and a sound card. I got the cache- first, I tried to use 128k, realized I needed a TAG chip, so got a set of 256k, found that some of the 256k chips were bad, and then used some of the chips originally intended for the 128k, and they worked together to make 256k.
When I started working on getting a sound card, I needed something SB16 compatible, so I bought a Vibra 16c on eBay. Between me purchasing the 16c and receiving it in the mail, I found a SS7 system for $5 at a thrift store, alongside a PB monitor and a couple of other things. There was an ISA ESS1869 sound card in there, and I had remembered seeing PhilsComputerLab where he had been messing with an ESS1868, and decided to use it instead.
When I first started using it, I got some DOS drivers online, and everything seemed to work great. I even installed Windows, got drivers for it, and it still was doing well. When I had to re-install DOS, I never got it working the way it did again. Here's what has happened:
When I installed the DOS drivers, got the IRQ and DMA "correct," the sound was fine. Both MIDI and sound effects worked great (mainly these tests were done in DOOM). I installed Windows 3.1, installed the drivers, went back to DOOM, the midi was fine, but the sound effects were awful. They sound crunchy, and far more "low-res," than they should've. I re-installed, didn't install Windows, and it worked just fine.
Later on, I decided to try Windows 95, struggled to find drivers for the card (most of them were broken), and when I did find a driver that worked, I had to manually change the IRQ to something DOOM could see before I got any sound effects from it under Win95. It worked great, but Windows 95 lied, because I get worse performance in DOOM under Windows than in DOS, not better or equal performance. I tried restarting Win95 in DOS mode, but in that mode, I could only get MIDI sound, no sound effects whatsoever, even when I set everything correctly in DOOM setup.
So then I changed back to DOS 6.22, installed the sound drivers, launched DOOM, and without Windows being there, that "crunchyness," had returned. So, I went back online, suspecting it was the drivers, got DOS drivers specifically meant for the ESS1869, installed them, but when I tried to run them, it said that the card was configured via PnP, and that it could do nothing. The IRQ and DMA numbers were crazy, way above what DOOM could ever hope to see, and in the BIOS of this machine, there is no way to disable PnP, nor is there any jumpers on the card or motherboard to disable PnP.
Will I have to break and spend the money on an OG SB16 that has no PnP? Would the Vibra 16c work in DOS better than the 1869, or would it be the same, and if I used it, would the audio (mainly the MIDI) sound like garbage?
I also have a non-PnP (I think, it has a little box with DIP switches on it that you can flip back and forth to change the IRQ and so on) Future Domain SCSI card installed, with an attached CD-ROM. I doubt it's the SCSI card, as it was working fine before with said card, and I doubt it has to do with the mods I made to the 486 before, as this problem was present when it was in its old case, unmodified. I'm not currently at that PC, so I can't really get much more information at the moment, but I don't want to give up on it and just have a 486 lying around, unused. I've wanted a 486 for years, and I'll be damned if I am going to let it go to waste, especially after spending a week and a half modding it into that new case.
Where am I?
Reply 2 of 18, by athlon-power
ShovelKnight wrote:
For what it’s worth, I’m unable to get my ES1869 working properly as well: Garbled sound in Windows 98
It works in DOS, but in Windows digital audio is horribly distorted.
Bleh. Phil praised the ESS1868 so much, but you get one number off, and it's ESS hell. At least you have a BIOS you can try addressing the PnP garbage with, mine simply doesn't mention it anywhere. Plug 'n Pray is sin even if your BIOS seems to support it.
Where am I?
Reply 3 of 18, by appiah4
Drop that ISA card into a PC with PnP support and change its IRQ and DMA to 5/1 or 7/1 using ESSCFG.EXE and when you move it back to your 486 it will probably work fine again.
Reply 4 of 18, by athlon-power
I figure I could drop it into my SS7 machine and run that and see where I get. I just with the thing had a NO SIN jumper on it where it disables PnP. To anybody who is designing a new ISA PnP card that allows for PnP to be disabled: Please make a jumper that allows for PnP to be disabled, and name it DISABLE SIN. Thank you.
DISABLE SIN: PINS 1-2
ENABLE SIN: PINS 2-3
Where am I?
Reply 5 of 18, by ShovelKnight
Does it actually have an EEPROM that saves the settings?
Reply 6 of 18, by appiah4
I don't know how that crap works but the ESS cards I have seem to remember what you set with ESSET. I think they are configuration registers that are somehow stored on the card, possibly on the PnP controller.
Reply 7 of 18, by athlon-power
I know that I used to have an old ISA RJ45/BNC based network card that saved the settings you applied to it using a DOS utility, but I'm pretty sure that one has an EEPROM. I'm also unsure as to whether or not the ESS has one or not.
Where am I?
Reply 9 of 18, by athlon-power
derSammler wrote:
There's no EEPROM on these cards. When you set the resources via ESSCFG, it will add a line to autoexec.bat which will init the card on each boot with the settings made.
Hm. Not sure what I can do now, considering that this is technically what I've been doing the whole time, just with drivers that "work," but were likely incorrect. I'd like to use the drivers that are more meant for the card, but that PnP crap is detected by the software and it notes that the card has already been configured by the BIOS, or something like that. I went to the effort to take the card out to search for a jumper before, but I never found one, which frustrates the situation more so than it would've if it was like the SCSI card, just non-PnP, or at least, giving you a choice between using PnP or not. I think the motherboard is at fault here more than anything- if it would at least allow me to disable PnP, or allocate specific resources to the card, this might not be as much of an issue, but being that this is an IBM OEM board, it doesn't give me such liberties.
Where am I?
Reply 10 of 18, by gdjacobs
IIRC, use the 1868 drivers as the newer ones don't allow you to specify IRQs and DMA channels.
Reply 11 of 18, by ShovelKnight
They do, but only if the card isn't configured by PnP BIOS.
Reply 12 of 18, by gdjacobs
Well, that makes sense. The older drivers allow you to force an override, so I recommend using them instead of the newer versions.
Reply 13 of 18, by appiah4
This is not correct.
http://www.electroscheme.ru/datasheet/ESS-tech/PB1868C.PDF
Plug and Play Features […]
  • On-chip Plug and Play support for audio, joystick port, FM, modem, MPU-401, CD-ROM, and an dditional user-defined I/O device
  • Software address mapping, and 4 DMA and 6 IRQ selections for motherboard implementation
  • Internal configuration data for audio Plug and Play support
  • Read/Write serial interface for Plug and Play resource EEPROM
Emphasis mine.
Also if you look on page 2 you will see that PINs 21, 22 and 23 are used for communicating with the PnP EEPROM.
As such, these cards can remember the last PnP because they can write to an external PnP EEPROM. And some cards do have an External EEPROM. I no longer have an ESS card with an EEPROM in my collection unfortunately (though I do have YMF and OPTI cards with 93C66 EEPROMs) but this card for example, has a solder pad for it (93C66), but it's not actually mounted:
But this one on Amoretro.de actually does have a 93C66 on it for the PnP Data EEPROM:
This one has an SMD EEPROM IC, the HT93LC66P:
And of course quality boards like the Terratec Gold 16/96 obviously have that EEPROM 93C66 as well:
So yeah, I don't know exactly what the ES1869 card in the OP's PC is like, but I would assume the issue is there because the card has an EEPROM and the data in the card's EEPROM defaults it to IRQ/DMA that one wouldn't want on an SB Pro (Weird shit like IRQ 9, DMA 0 etc).
@athlon-power can you please post a photo of the ES1869 card you are using?
Reply 14 of 18, by derSammler
@appiah4:
Did you actually read what you just posted? Of course it has storage for Plug and Play data, otherwise the card could not work in a PnP system. And the text you've quoted even says exactly that.
At least I was talking about ESSCFG, which is for non-PnP mode and there is no EEPROM to store the settings made with ESSCFG! In non-PnP mode, ESSCFG must be called on each boot via autoexec.bat.
Reply 15 of 18, by appiah4
derSammler wrote:
@appiah4:
Did you read what you actually posted? Of course it has storage for Plug and Play data, otherwise the card could not work in a PnP system.
That is not how ESSCFG works. You can call ESSCFG from Autoexec.bat before SET BLASTER and it still retains the previous PnP configuration.
Reply 16 of 18, by derSammler
No, you can't, since ESSCFG does not even work when the card is in PnP mode... Please learn the difference between using the card in non-PnP mode using ESSCFG and having the card set up by PnP. This makes a huge difference in how the card works.
Reply 17 of 18, by appiah4
Ok, look, I don't want to start a huge argument over it because I don't have a system to test this out with me at the moment but ESSCFG.EXE does exactly what you say it does not: It configures the card for PnP mode.
Grab this DOS driver pack: https://www.philscomputerlab.com/ess-audiodrive-es1868.html
So we call ESSCFG /? at command line, and here is what it does:
70.94 KiB
If you want more proof download the ES688 driver disks here: http://www.vogonsdrivers.com/getfile.php?file … menustate=46,36
On the README.TXT from Disk 1:
[ ESSCFG.EXE ] […]
[ ESSCFG.EXE ]
ESSCFG.EXE is a DOS utility program for setting or display the
IRQ channel and DMA channel of your Sound Card. This program
can override the settings of hardware jumper and let you change
the setting without turning off your system.
To use this program:
1. Change to the directory where the Sound Card software is
installed.
2. Type "ESSCFG" and press <ENTER>.
3. The program will detect and display the I/O address, current
IRQ channel and DMA channel settings of the Sound Card.
4. Follow the instruction on screen to select the function or
exit the program.
Emphasis mine. Note Number 3; it detects the PnP configuration STORED on the card. It can do this without a SET BLASTER environment. On cards without Non-PnP setting jumpers.
You want more proof? Go here: http://www.daqarta.com/ess.htm
These guys have alternative drivers for ESS cards, and here's what they say for ESSCFG.EXE:
This driver does not directly configure PnP (Plug 'n Play) cards. It reads the base address, IRQ, and DMA settings for the card from the BLASTER environment string, which should be set by a PnP configuration manager such as ESSCFG.EXE, or by a SET BLASTER= line in your AUTOEXEC.BAT file.
Emphasis mine.
More proof that it can be used with PnP, Guillemot Maxi Sound drivers: ftp://retronn.de/driver/Guillemot/MaxiSound64 … c3D/DOSMAXI/ESS
From the Readme:
ESSCFG.EXE allows the user to configure the ESS sound chip with a base address, a DMA channel, an IRQ channel, and an address fo […]
ESSCFG.EXE allows the user to configure the ESS sound chip with a base address, a DMA channel, an IRQ channel, and an address for the MPU-401 port, if a wavetable is supported by the sound card.
ESSVOL.EXE allows the user to configure the output volume level of the mixer in the sound chip.
Plug & Play O/S: Yes
1. Type ESSCFG [Enter]. This will display the current setting and selected menu to change the desire setting.
2. ESSCFG /? [Enter]. For help.
3. Type ESSVOL [Enter]. Display selected menu to change the desire setting.
4. ESSVOL /? [Enter]. For help.
Typical parameters are:
Address: 220
DMA: 1
IRQ: 5
MPU-401: 300
When finish, hit ESC and prompt will ask to save to config.sys and autoexec.bat [YN]
Plug & Play O/S: NO
1. Type ESSCFG [Enter]. This will display the current setting.
2. Type ESSCFG ! This will allow changing the setting.
3. Type ESSVOL [Enter]. Display current volume setting.
4. Type ESSVOL /? [Enter]. For help.
5. Type ESSVOL /(character). This will allow changing the setting.
Address: 220
DMA: 1
IRQ: 5
MPU-401: 300
So yes, ESSCFG.EXE does cofnigure PnP and the card retains these settings. The settings are stored in the PnP EEPROM. So when you install an ESXXXX card, on a PC without PnP, you can not reconfigure these settings and the card defaults to the last settings set using ESSCFG.EXE.
So @athlon-power, to resolve this argument once and for all please stick your soundcard into a PnP capable PC, and run "ESSCFG.EXE /A:220 /I:7 /D:1 /M:e /B:330 /J:e" there, then move it back to your 486 and see if that fixes the issue.
Reply 18 of 18, by athlon-power
Oh.
I'll get around to doing that tomorrow. I can just throw it in my Super Socket 7 system and run that, and return it to the 486.
I'm semi-paranoid about keeping the ISA cards in that thing because the card slots don't exactly match up with the brackets from the modification I did and so they tilt upwards a few millimeters, causing them to flex. The SCSI card already seems to have permanently taken on this bend instead of returning to normal when I remove it, which makes me worry that I might damage them if I use that system long enough. But I will indeed try that and see if it takes a liking to it or not.
Where am I?
