First post, by appiah4
I used Warp 3 with a DX33 andlater a DX4-100 back in the day. I firmly remember it performing perfectly well on 486 CPUs, but I never used 486 hardware for Warp 4. If I remember correctly, I had moved onto a Pentium by the time I moved on to Warp 4. So my question is, is a fast DX4 fast enough for Warp 4 or is a Pentium particularly recommended?
Reply 1 of 8, by rmay635703
It will physically run if you have 16mb
Fast enough is subjective, I say go for it and report back
Reply 2 of 8, by appiah4
Those requirements are highly suspect, there is no way a desktop OS in 1996 could require 1GB of hard disk space..
Reply 4 of 8, by derSammler
The Warp 4 box says:
486/33 MHz with 12-16 MB RAM
200 MB hard disk space for "Easy" installation (100-300 MB when using custom installation)
As long as you don't install all that Speech stuff Warp 4 comes with, it should work nice and fast on a DX4-100. Like with Windows NT, RAM is more crucial to performance than raw CPU power.
Reply 5 of 8, by Jo22
derSammler wrote:
RAM is more crucial to performance than raw CPU power.[
I think the same. From a personal point of view, RAM and slow hard disks were often to blame for bad performance.
OSes like Windows 3.x, NT, 9x and OS/2 run best if they haven't to worry about running out of memory.
16MiB or more for OS/2 Warp is fine. 4MiB is the bare minimum for OS/2 (just like Win95 Retail specs said) and absolutely not recommended.
It's even mentioned in that OS2 video: https://youtu.be/-DAojx2Hgec?t=2760
Btw, that "64MiB Option" in some BIOSes is relevant for Pre-Warp cultures only. 😉
Edit: Several edits.
Reply 6 of 8, by appiah4
To elaborate, I am undecided between an Am486DX4-100 32MB system vs a K5-PR166 64MB system.. I want to build a 486 but I'm not sure I will be comfortable with its Warp 4 performance.
Reply 7 of 8, by Jo22
May I ask if you do have got a powerful main PC ?
If so, you could try to configure PCem with the specs mentioned above and see if it works well enough for you. 😀
