First post, by HanJammer
What options do I have when it comes to MPU-401 intelligent mode on 286?
I need it to play around with some early midi software (I own external midi devices - controllers and synths I want to use with that) and to play games on my MT-32. I know about SoftMPU but it requires virtual mode which is available on 386-up making it virtually useless for my purpose. True Roland devices are hardly available and have crazy prices, I know there are modern MPU-401 compatible interfaces (which one is the best?) or vintage compatible interfaces (again, hardly available). I guess I can use some sound cards with proper MPU-401 compatibility built in as well (which ones? I own PAS16, but I guess it doesn't have intelligent mode, right?).
So what's the easiest/cheapest way to make it running on 286?
Reply 1 of 19, by Tiido
These would be a good solution : www.amibay.com/showthread.php?109229-PC ... ble-header
I'm not sure what are the cheaper options, all of the intelligent mode things seem to be fairly costly.
Reply 2 of 19, by HanJammer
Thanks, that's pretty expensive though. I bought MT-32 for similar price not too long ago (complete with original manual and so on)...
Reply 3 of 19, by maxtherabbit
that's pretty interesting
any chance that it is an open source design?
Reply 6 of 19, by keropi
MIDI-IN exists and is fully functioning on the DB9 port but like derSammler mentions is it not needed for playback/games so the cables come configured as OUT ones unless requested otherwise.
Reply 7 of 19, by dionb
I occasionally see MusicQuest cards going cheap locally, usually from musicians not into retrocomputing who just see them as no longer useful old crap. Managed to nab two that I'm very happy with.
Reply 8 of 19, by HanJammer
derSammler wrote:
HanJammer wrote:
Also the above interface is only midi out 🙁
MIDI Out is what you need, based on your original post. Or do you plan to connect a keyboard to that 286?
Well... I mentioned controllers (like keyboards, sequencers) - that implies midi-in is needed... 😀
But if it does have midi-in then it's something to think about.
I will add this keyword to my watch list then 😀 thanks.
Reply 10 of 19, by darry
dr.zeissler wrote on 2022-11-02, 21:43:
Would be nice if such a MPU401 card had a OPL2/3 onboard but such cards do not exist.
Orpheus II does that, and more.
If a theoretical Orpheus III added an SB16 compatible chip, that card would basically cover the 90s and most of the 80s, in a single card.
Reply 11 of 19, by Jo22
Not yet. Maybe the community will create something like this ?
It's more likely than a replica of the "woodgrain 386", hah. 😁
129.97 KiB
Source: https://hackaday.com/2022/11/01/dana-sibera-c … hat-dont-exist/
HanJammer wrote on 2019-12-03, 14:06:
In theory.. It's possible to give an 80286 system this ability by using external logic.
I remember that PC-MOS/386, an MS-DOS compatible multi-tasking OS, supported an external MMU
that could be installed between the 80286 and its mainboard.
With the MMU in place, the 80286 could support memory management and multitasking similar to an 80386.
Reply 12 of 19, by darry
Jo22 wrote on 2022-11-02, 22:26:
Not yet. Maybe the community will create something like this ? It's more likely than a replica of the "woodgrain 386", hah. 😁 […]
In addition to the soon to be released Orpheus II (which I meComputersin my previous post), the AWE64 Legacy has both a HardMPU and an OPL3 .
AFAICR, an external MMU for 286 CPUs did exist as a commercial products I think the manufacturer was "ALL Computer" and was named "ALL Chargecard". I am not 100% on the actual names. It was not compatible with 386 MMU functionality, again AFAICR.
Reply 13 of 19, by Jo22
darry wrote on 2022-11-02, 22:33:
You're right, it exists! 🙂👍
https://www.youtube.com/watch?v=xgMIbo6QoM4
Well, it surely wasn't instruction compatible.
Otherwise it would have had interfered with the 286's own 286 MMU, which the 386 MMU is based upon.
However, it had a driver diskette with a LIM 4 compatible EMS driver, at least.
So DOS compatibility was provided.
And if it was related to the card mentioned in PC-MOS documentation,
it might have been able to do more than just providing Expanded Memory.
If would have had the ability to trap interrupts and memory writes/reads.
Which would allow us to add support for it into SoftMPU.
That would be impressive. If only we had access to the information about the MMU chip!
An FPGA could be used to mimic its behavior.
Let's think about it, this would breath new life into the 286 platform!
There are so many new Open Source projects!
PC-MOS/386 has its source code at Github, PC GEOS became FreeGEOS, there's OpenGEM..
Such a little interposer card could bring homebrewing to a new level!
Sute, someone could also claim that a 386 upgrade board could do the same.
But then we're dealing with V86 again, and all it's compatibility issues.
That ALL Chargecard board's MMU could maybe co-exist with a 386SX chip, even.
If that's the case, it could brighten up the days for 386 owners, too!
Imagine, an external MMU for 80386/80486 motherboards.
That would be awesome. QEMM like memory managers that don't need V86. Yahoooo! 😁
Edit: Or let me pput it this way:
If that MMU is able to listen/write to any memory address, it could talk/listen. to the 80286!
The 80286 writes data into a "void" were no physical hardware existes, but the MMU is listening to. Or vice-versa.
Things like a virtual COM port driver will become possible then.
A game writes MPU-401 data to port 330h, where the ALL Chargecard MMU is listening.
The MMU then will transfer the data to SoftMPU, which processes the data and sends it to port 300h, were the sound card with the dumb MPU-401 is located.
All this in Real-Mode! As if we're using a MIDIQuest card.
Reply 14 of 19, by HanJammer
That would be way too much of a card for 5170 or any 286...
I do have accelerators and so on for XT or 286 machines, but again - for me it's not "real" 286 with such improvements (also it's just for 5170 or other machines with PGA package CPU or at least PLCC socket, my main 286 multimedia machine has soldered-on Harris CPU which would I have to replace with the PLCC socket... not really thing I would want to do)... Not to mention this thing is perhaps harder to find than Roland MPU-401 with the breakout box or at least some other MPU-401 card...
Reply 15 of 19, by darry
HanJammer wrote on 2022-11-03, 00:36:
That would be way too much of a card for 5170 or any 286... […]
Definitely overkill for a 286.
I wonder if something like a Pi Pico (or barring that a zero or a full Pi) could be used to implement an intelligent mode MPU-401 and possibly allow for installing an OPL3+DAC (with optional FM software emulation instead and maybe even SBPro/SB16/PAS16/etc) at lower cost than other current solutions for intelligent mode MPU-401
Polpo's work on PIGUS might be laying the groundwork for that : PicoGUS: ISA sound card emulator with Raspberry Pi Pico (Gravis Ultrasound, AdLib, MPU-401, Tandy, CMS)
Let me know if any of this makes sense, I'm no expert in this field .
Reply 16 of 19, by Jo22
Yikes, it depresses me a bit you guys are so conservative here. This road may lead to the grumpy old men avenue. 😉
Reply 17 of 19, by darry
Jo22 wrote on 2022-11-03, 04:53:
Are you referring to me ? I am not against adding modern and/or overkill stuff to older machines. Did I give the impression that I was set in my retro ways ?
I do reserve the right to someday progress to grumpy-old-man-dom and yell at a cloud 😉
Reply 18 of 19, by rasz_pl
darry wrote on 2022-11-03, 02:42:
It looks like hardmpu was just added 8 days ago to the readme https://github.com/polpo/picogus/commit/39123 … 2bc32d1ac0ff12b but I dont see it implemented in the code. Looking at the changelog DMA seems to be working now maybe? Both still in todo phase on https://github.com/polpo/picogus/wiki
Reply 19 of 19, by darry
rasz_pl wrote on 2022-11-03, 07:03:
Getting closer to the retro PC equivalent of https://en.m.wikipedia.org/wiki/Ship_of_Theseus
