Reply 580 of 878, by vorob
- Oldbie
Just wanna share some pictures. Because i can.
Nice looking machine!
vorob wrote on 2021-08-04, 14:14:Just wanna share some pictures. Because i can.
how does it work? is it good?
Since i've got only 64mb flashcard i've installed only doom, commander keen and prince of persia. They all work well, and i've got sound and gm music without drivers.
One issue so far, and it is covered here:
By default320x200 games are just a small window in center, no build-in option to stretch it. When i use VEXP utility i'm able to make window bigger, but i still have borders and 320x200 is squeezed like i had on my toshiba 2805 with S3 videocard. Looks like it's best i can get here.
I'm trying to enable USB on this Siemens. All other PC's work with this thing:
DEVICE=HIMEM.SYS /TEST:OFF
DOS=HIGH
DEVICEHIGH=USBASPI.SYS /V /W
DEVICEHIGH=DI1000DD.SYS
But this one find no devices. Maybe there is another approach? Another dude made another way to work with USB under DOS?
Variations on that theme... USB storage drivers that work in DOS 6.22?
BitWrangler wrote on 2021-08-05, 22:26:Variations on that theme... USB storage drivers that work in DOS 6.22?
I'll try, thanks.
Honestly, if this laptop is really from 1997 i don't get how USB exist there. And i see no drivers on FJS support page. What was the use case for it back then?
Thanks once again! This thing solved the issue: http://bretjohnson.us/
Just used two exe files and my flash drive is available in dos. The speed though is super slow, but it's better then nothing.
As for a lappy, i'm happy for now 😀 No drivers, no dancing with the settings. I just choose GM or roland and game produce rich music! Now i'm waiting for my 2gb compactflash.
Just received my 2gb compact flash card for my Siemens Nixdorf Scenic Mobile 710. Now i'm packing it with games like a madman. I've also installed Win 98 and it supports USB with better speed than i had in DOS. So far all stuff i'm launching is working like i expect it to work: for music i'm selecting mt32 or sound canvas or general midi and for sound just sound blaster. And it works. Just works!
The only game where i face issues is Dune 2, can't have both gm music and sound effects...
I got a standard 1GB CF card installed on my Toshiba Satellite Pro T2150CDT internally (attempted to use a 512MB Industrial and 1GB Industrial CF cards to no avail (either freezes up or not detected) and copied all of the files from the 527MB image of the old hard drive onto the CF card once I was done formatting it.
And it's a lot more silent than before.
The Dune issue is solved. For now, I can't see a reason why Siemens Scenic Mobile 710 can't be called an ultimate dos gaming machine. Well, maybe its scaling can be a weak point. Mode 13h is squeezed...
I Bought CD-ROM for my lappy. Couldn't live with a dead battery, useless waste of space.
Capturing some samples from my Siemens. Direct capture. If you know some tough gm music games, name them please.
my disappointment is immeasurable and my day is ruined!
all that work cleaning out the heavy corrosion of the NiCad pack and disassembling... for this? 😁
...though I guess the missing audio jacks should have been a sign ^^
vorob wrote on 2021-08-17, 22:14:The Dune issue is solved. For now, I can't see a reason why Siemens Scenic Mobile 710 can't be called an ultimate dos gaming machine. Well, maybe its scaling can be a weak point. Mode 13h is squeezed...
I don't like the keyboard feeling. Also mouse buttons are flimsy. Machine wise it pretty good. My has Tillamook 266.
imi wrote on 2021-08-22, 20:42:my disappointment is immeasurable and my day is ruined! […]
...though I guess the missing audio jacks should have been a sign ^^SKD-4000.jpg
What exactly am I looking at here?
It's what isn't there.... like all the sound chips.
BitWrangler wrote on 2021-08-23, 03:16:It's what isn't there.... like all the sound chips.
What, is it supposed to be missing (as in, did it came from a 486 laptop that has a multimedia option…which is not populated in certain models)?
The 83c611 and the CT65540 chips pretty much point to it being on a VLB machine.
crippled version. Still fairly content with my Toshiba 2805-s402. It's basically perfect, I just wish the LCD was a better quality. I might try upgrade the LCD some day to IPS or a newer technology.
ragefury32 wrote on 2021-08-23, 05:39:What, is it supposed to be missing (as in, did it came from a 486 laptop that has a multimedia option…which is not populated in […]
yeah, it's a nice 486 VLB laptop, what could have been is also a nice 16-bit sound section with real OPL3, as seen here: http://www.ombertech.com/cnk/skd-4000/img/Sma … /P1010001,s.jpg
while the components seem to be nicely labeled there's still a million SMD resistors and capacitors, so it would be kinda hard to populate all of that let alone know what values exactly 😒
would have been a nice project to try and swap in a color TFT, but without sound it's kinda pointless.
