I would think so 😀 That name kind of obligates...
here is the contents of it:
Volume in drive A has no label.
Volume Serial Number is 14F2-3E20
Directory of A:\
1990-12-07 14:13 4ÿ149 3OPEN.DOC
1990-09-28 15:28 1ÿ067 STIARA.LAN
1991-01-08 08:50 7ÿ163 README
1990-09-28 15:19 1ÿ285 TIARA.LAN
1990-11-27 14:50 7ÿ868 NETWARE.DOC
1990-09-28 15:23 10ÿ122 STIARA.OBJ
1990-09-28 15:24 7ÿ498 CTIARA.OBJ
1990-09-28 15:24 7ÿ498 BTIARA.OBJ
1991-01-08 07:51 4ÿ401 BANYAN.DOC
1990-09-28 15:24 7ÿ498 ATIARA.OBJ
1990-12-07 14:20 4ÿ467 LANMAN.DOC
1990-09-28 15:24 7ÿ498 DTIARA.OBJ
1990-12-07 14:22 8ÿ460 NDIS.DOC
1991-10-02 15:37 <DIR> 3OPEN.110
1991-10-02 15:38 <DIR> BANYAN.400
1991-10-02 15:38 <DIR> DIAGS
1991-10-02 15:38 <DIR> MSLANMAN.110
1991-10-02 15:39 <DIR> MSLANMAN.DOS
1991-10-02 15:39 <DIR> MSLANMAN.OS2
1991-10-02 15:40 <DIR> NETBIOS
1991-10-02 15:41 <DIR> NETWARE.386
1991-10-02 15:41 <DIR> PCNFS
1990-11-29 09:28 5ÿ953 @6000.ADF
1990-11-29 09:31 5ÿ961 @6001.ADF
1990-11-29 09:32 5ÿ960 @6002.ADF
16 File(s) 96ÿ848 bytes
Directory of A:\3OPEN.110
1991-10-02 15:37 <DIR> .
1991-10-02 15:37 <DIR> ..
1991-10-02 15:37 <DIR> OS2
1991-10-02 15:38 <DIR> DOS
0 File(s) 0 bytes
Directory of A:\3OPEN.110\OS2
1990-11-14 11:35 505 PROTOCOL.3CM
1990-11-14 11:37 195 TNDIS.NIF
2 File(s) 700 bytes
Directory of A:\3OPEN.110\DOS
1991-10-02 15:38 <DIR> .
1991-10-02 15:38 <DIR> ..
1990-11-14 11:36 195 TNDIS.NIF
2 File(s) 700 bytes
Directory of A:\BANYAN.400
1991-08-30 16:32 368 PROTOCOL.INI
1 File(s) 368 bytes
Directory of A:\DIAGS
1990-06-19 14:40 102ÿ371 INST_E.EXE
1990-11-27 13:13 1ÿ995 DIAGS.DOC
1980-01-01 00:45 215 TIARA.CFG
3 File(s) 104ÿ581 bytes
Directory of A:\MSLANMAN.110
1991-10-02 15:38 <DIR> OS2
1991-10-02 15:39 <DIR> DOS
0 File(s) 0 bytes
Directory of A:\MSLANMAN.110\OS2
1990-11-14 11:40 340 TNDIS.NIF
2 File(s) 708 bytes
Directory of A:\MSLANMAN.110\DOS
1991-10-02 15:39 <DIR> .
1991-10-02 15:39 <DIR> ..
1990-11-14 11:39 340 TNDIS.NIF
2 File(s) 708 bytes
Directory of A:\MSLANMAN.DOS
1991-10-02 15:39 <DIR> DRIVERS
0 File(s) 0 bytes
Directory of A:\MSLANMAN.DOS\DRIVERS
1991-10-02 15:39 <DIR> NIF
1991-10-02 15:39 <DIR> ETHERNET
0 File(s) 0 bytes
Directory of A:\MSLANMAN.DOS\DRIVERS\NIF
1990-08-23 19:21 157 TNDIS.NIF
1 File(s) 157 bytes
Directory of A:\MSLANMAN.DOS\DRIVERS\ETHERNET
1991-10-02 15:39 <DIR> TNDIS
0 File(s) 0 bytes
Directory of A:\MSLANMAN.DOS\DRIVERS\ETHERNET\TNDIS
1991-09-03 14:27 9ÿ584 TNDIS.DOS
2 File(s) 9ÿ952 bytes
Directory of A:\MSLANMAN.OS2
1991-10-02 15:40 <DIR> DRIVERS
0 File(s) 0 bytes
Directory of A:\MSLANMAN.OS2\DRIVERS
1991-10-02 15:40 <DIR> .
1991-10-02 15:40 <DIR> ..
1991-10-02 15:40 <DIR> NIF
1991-10-02 15:40 <DIR> ETHERNET
0 File(s) 0 bytes
Directory of A:\MSLANMAN.OS2\DRIVERS\NIF
1990-08-23 19:22 157 TNDIS.NIF
1 File(s) 157 bytes
Directory of A:\MSLANMAN.OS2\DRIVERS\ETHERNET
1991-10-02 15:40 <DIR> TNDIS
0 File(s) 0 bytes
Directory of A:\MSLANMAN.OS2\DRIVERS\ETHERNET\TNDIS
1991-09-03 14:28 9ÿ542 TNDIS.OS2
2 File(s) 9ÿ910 bytes
Directory of A:\NETBIOS
1990-08-14 16:23 67ÿ029 NETBIOS2.EXE
1990-11-27 10:04 6ÿ599 NETBIOS.DOC
2 File(s) 73ÿ628 bytes
Directory of A:\NETWARE.386
1991-10-02 15:41 <DIR> .
1991-10-02 15:41 <DIR> ..
1990-09-04 11:55 11ÿ411 TIARAE.LAN
1 File(s) 11ÿ411 bytes
Directory of A:\PCNFS
1990-05-02 17:55 4ÿ624 TIARA.SYS
1989-08-16 11:13 17 WHAT.BAT
1990-11-27 14:42 2ÿ202 PCNFS.DOC
1989-08-16 10:08 16ÿ712 MYEADDR.EXE
4 File(s) 23ÿ555 bytes
Total Files Listed:
41 File(s) 333ÿ383 bytes
63 Dir(s) 350ÿ208 bytes free
