First post, by sledge
- Newbie
I'm working on all-purpose "one rig to rule them all" DOS/Win9x Pentium III build. Planned specs as follows:
ECS P6BAP Me (ISA slot for sound card! 😀
Pentium 3 1GHz (anything above 800MHz will do)
256MB RAM
SB AWE32 (with real OPL3)
GeForce2 GTS (GeForce4 MX440 at the moment)
modern PSU (probably Seasonic SS-350ET)
some kind of flash based storage (SD, CF, SSD...)
And here comes the troubles: right now I've got one 700MHz CPU (SL3XX) and two 800MHz CPUs (SL4CD). SL3XX runs flawlessly, but none of the SL4CD works. Mobo has latest BIOS (1.4a) and fast coppermine CPUs should be supported. When MB is switched on, CPU fan spins for a brief moment, then stops and nothing else will hapen. Tried to force 133MHz FSB via jumpers, nothing. Is there anything else I could try? Or am I just unlucky and both SL4CD are simply dead? Or am I missing something? 😀
