First post, by MKT_Gundam
My P3BF v. 1.04 dont have the Jumper free/Manual header.
Theres other way to enable or just my mobo revision?
Tee BIOS vrsion is 1006.
How i will set the dip switches for later cpus like pIII 800mhz or 1ghz?
The manual at ASUS site only show for p3 600 and below.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 2 of 9, by meljor
MKT_Gundam wrote on 2020-01-03, 22:47:
My P3BF v. 1.04 dont have the Jumper free/Manual header. Theres other way to enable or just my mobo revision? Tee BIOS vrsion i […]
Jumperfree will be set when ALL dipswitches are set to ''off''. Settings should be available in bios after that.
If it doesn't work just use the switches? It's way easier than using jumpers on other boards....
Reply 3 of 9, by MKT_Gundam
Here
https://ibb.co/M7Mn115
https://ibb.co/ZV75LBN
https://ibb.co/M9kyLHR
https://ibb.co/pWnhztt
This board came with a slotket and pentium 3 600E
The slotket model is here:
https://ibb.co/7RYG5xz
Reply 4 of 9, by PARKE
The jumperfree block sits just above the control panel at the right side. It is marked with [JEN] and there is a blue jumper installed on pin 1 and 2. Move the jumper to pin 2 and 3 for jumperfree mode and adjust the dipswitches in the blue block as indicated bij Meljor.
Reply 5 of 9, by meljor
PARKE wrote on 2020-01-04, 15:36:
Yup... missed the JEN jumper part but that's right.
BTW, the 800mhz cpu should be multiplier locked so just plug it in and make sure it gets the right 1.7v-1.8v and it should work unless your bios version doesn't support that core (in that case upgrade bios version).
Reply 6 of 9, by PARKE
He has the 1006 Bios and should be fine I think.
bx3f1006.zip P3B-F (Intel 440BX chipset) M/B, PnP BIOS ver. 1006 30/Jun/2000 1. Fix Windows 2000 cannot be installed if all Pn […]
bx3f1006.zip
1. Fix Windows 2000 cannot be installed if all PnP devices in Super I/O are disabled.
2. Support 566MHz and 850MHz CPU with clock ratio equal or greater than 8.5x.
3. Revise Coppermine Vcore limit for 128K cache Coppermine.
4. Fix Hardware Monitor false alarm of CPU vcore when using old celeron CPU.
[unquote]
Reply 7 of 9, by MKT_Gundam
Now checking my photos .....The JEN is really above the control panel headers :p.
The manual at ASUS site has a different layout.
Thnaks for the help guys!
Reply 8 of 9, by Horun
I have a Asus P3 board and the jumper free mode does not work with all processors (the P3 550 E series I had issues with). Be sure to reset the BIOS if you cannot get the new cpu to POST.
Reply 9 of 9, by PARKE
MKT_Gundam wrote on 2020-01-04, 17:06:
The P3B-F manuals cover three versions of the board: no ISA, 1x ISA and 2x ISA.
Your board has 2x ISA and does not correspond 100% with the graphics in the 1.04 manual.
