First post, by Violett'Blossom
I have only one board ATM with Intel 955X chipset which only supports Pentium Dual Cores...
How much it will bottlenec GTX 8800 ?
Thanks in advance 😀
Retro gaming : Compaq Armada E500
Portable : MacBook Air 2012
Hackingtosh : I5 6500 8GB DDR4 RX480 8GB
Reply 1 of 4, by SPBHM
it depends in some games it's pretty brutal in others you will not notice,
8800GTX is better matched with a fast C2D.
if you check the 8800GTX reviews they were mostly using x6800s (C2D 2.93GHz) and such which is way faster in some games compared to any pentium D.
Reply 2 of 4, by ifrit05
Pretty much. Remember, a Pentium D is really just 2 Pentium 4's slapped together on the same die (Smithfield based on Prescot, or the newer Pesler based on Cedar Mill).
NetBurst was terrible. It really shows how vastly superior the core micro-architecture was, all major intel CPU's are still using direct descendants of the original from 2006.
SS7: GA-5AA 1.1 | K62+ 550 @ 600 | 512MB PC133 | V3 3000 A500: Stock A1200: Indivision AGA MK2cr | ACA 1221 Apple IIGS Macintosh IIci Atari 800XL
Reply 3 of 4, by matze79
And Core is based on Pentium M who is based on Tualatin..
no good CPU comes from Intel America.
Israel did it.
Co2 - for a endless Summer
Reply 4 of 4, by RaverX
It depends on the game and the settings. On very high resolution it might not be an issue, but in general that CPU is quite a big bottleneck. I had 8800 Ultra back in the day and it was paired with Q9450. I'd go with something similar or even better. Core2 Duo might be also ok, E8600, but E8400 is not bad and you can found those very cheap, basically for free.
