First post, by FrankDM
Hello
I was looking at some of my floppy drive pins at the back for data transfer and noticed that I have 3 different configurations... why? Do all of these work on everything?
Image:
https://ibb.co/6ZmrFm1
Just thought this was weird...
Reply 1 of 2, by Horun
On standard 34 pin floppy connectors the bottom row is all ground, they are not all required but there is a benefit of having all the ground pins: helps suppress noise and crosstalk from interfering with the data signals in the cable.
Reply 2 of 2, by Caluser2000
FrankDM wrote on 2020-01-05, 21:20:
Hello […]
Hello
Image:
If they are 34 pin in good condition yes they will work on any system that accepts 34 pin 720k/1.44mg floppy disks.. Some even have the power connect on the other side.
