First post, by Lo-ResBros
I got a K6-2+ 550MHz in a Super socket 7 pcb (Soltek SL-54U5) that doesn't want to post if I set it at normal 2.0V but works with 2.1V. Is it safe to run it at this voltage?
AMD K6-2+/550MHz
Soltek SL-54U5 Super Socket 7
64MB SDRAM
3DFX Voodoo 3 3000 16MB
Sound Blaster AWE64
Roland SC-55mkII
Pentium MMX 233MHz
Tyan TitanVX S1470 Socket 7
128MB SDRAM
ATi Rage 128 pro 32MB
Audio Plus 320 v.1
Roland SC-88
Reply 3 of 6, by cyclone3d
This is quite normal for these CPUs.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 4 of 6, by xjas
Yeah, mine doesn't work at 2.0V either. I wonder if AMD under-rated them all, or if they're just really intolerant of variance at 2.0V?
Reply 5 of 6, by sledge
Funny thing: I had to set my motheboard to 2.5V in order to get K6-III+ 450MHz run. With 2.1V I was stuck at POST, with 2.3V I managed to boot to Windows, only to be welcomed by BSOD 😀 But I guess this was some kind of error caused by cheap and low quality PC Chips M577 motherboard , and the actual voltage delivered by MB was lower than what was set by jumpers...
doshaven.eu / high-voltage.cz
Reply 6 of 6, by gex85
I have a couple of K6-2+ 550 CPUs that run happily even at 600 MHz with 2.1V vcore. 😄
To set it to 600 MHz, use the 2x multiplier setting on your board, which translates to 6x internally in the CPU.
1992 - i486DX2-66 // 1997 - P1-233 MMX // 1998 - P2-350 // 2000 - P3-650 // 2001 - Athlon 1400 // 2003 - Athlon XP 3200+ // 2008 - Xeon E5450 // 2015 - Xeon E3-1240v5
