First post, by murrayman
I've got a late-1997 Packard Bell Multimedia S610 with a Sony CDU611 optical drive; BIOS confirms ATAPI compatible. I just restored the system using the PB 175525 Master CD and a PB Master Boot Floppy compiled using the MakeDisk file from the CD. The OS is Win95 OSR2 w/ USB supplement. The restored installation loaded all the drivers appropriate for DOS into the autoexec.bat, config.sys, and dosstart.bat files, except for a CD driver. While restoring the computer using a PB Master Boot Floppy, I used GSCDROM.SYS, and it worked just fine, so I copied the file to C:\Windows\System to use. Using a standard Win98 boot disk / CD also works just fine.
So, starting fresh, what do I need to do to load a working CD driver into DOS? I've tried putting in appropriate command lines in all three files mentioned above to no avail, so assume instead that this is my first time ever doing this sort of thing. What do I need to do?
Asus P3B-F 1.04, PIII 1.0GHz, 512MB PC133, V5 5500 AGP, SB0160
Asus P3B-F 1.03, PIII 933, 384MB PC133, GeForce DDR 32MB, SB0100
CP 5170, PIII 500, 256MB PC100, DM3DII 12MB, ESS 1868
PB M S610, PMMX 233, 64MB PC100, DM3D 4MB, Sound4
