First post, by EvieSigma
I have a Windows 98 machine with two optical drives (the factory DVD-ROM and a HP CD-RW added by a previous owner). These two drives show up just fine in the BIOS on the secondary IDE channel, but in Windows 98 they are nowhere to be found. They are not visible in My Computer, nor do they appear in Device Manager. I recently changed the motherboard on this machine but I don't see how that could have broken everything, especially since the hard drive on the primary IDE channel works absolutely fine. Is this some kind of driver issue?
Reply 1 of 5, by derSammler
Delete and re-install the drivers for the IDE controller. If you changed the motherboard, Windows may not use the correct drivers. Also check that the 16-bit compatibility mode for drive access is not used, as in that case Windows will only see optical drives when real-mode drivers are loaded in DOS.
Reply 2 of 5, by Tiido
REGEDIT4
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\IOS]
"NoIDE"=hex:00
Getting rid of "NoIDE" registry key will fix it f it exists at the HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\IOS location.
Reply 3 of 5, by Baoran
I had similar problem and it ended up being that the optical drives simply didn't like each other (At least didn't like being in a same ide cable even if they were correctly configured to be master and slave). Both worked alone and when I switched the second drive with different optical drive both drives suddenly appeared in win98. In dos I didn't have any problems accessing them with dos driver and mscdex.
Reply 4 of 5, by SirNickity
Just had this happen on an IC7-G. I'm not 100% sure what the problem actually was, but it had something to do with the way the ICH5R and the Silicon Image SATA controller can appear as legacy IDE and whether they share IDE channels 1/2 or enumerate as 3/4. The BIOS lets you choose from a couple of options. With various configurations, the BIOS would show my IDE and SATA optical drives, but Windows would only detect one or the other despite having the drivers for both controllers installed. I'unno. Finally got a combo Windows XP liked, so I let it be. Moral: Try them on different channels if you can.
Reply 5 of 5, by EvieSigma
I removed my unused PCI Ultra66 ATA controller (as the board has onboard ATA-100) and I thought that would have fixed it but the optical drives still aren't showing up under My Computer.
EDIT: turned out I just needed chipset drivers and all was well. That was surprisingly easy.
