First post, by EvieSigma
I have a Gateway with an OEM'd version of the Intel D815EEA motherboard. I want to update the BIOS but the problem is that the actual Gateway BIOS updates for this particular board are seemingly unobtainable, I've checked multiple sources and come up with absolutely nothing. However, I was able to find the Intel version of the BIOS very easily.
1. Can I flash the Intel version of the BIOS to this board? If so, how?
2. Is there some tool I can use to mod the BIOS to still have the Gateway logo?
Reply 1 of 8, by Fujoshi-hime
I wouldn't do it unless you had access to the necessary hardware to externally write to the EEPROM chip, like a BusPirate or something. Or at least a spare vanilla EEPROM to swap in. The mobo would PROBABLY refuse to flash an incompatible firmware, PROBABLY, but if getting nitty gritty with EEPROMs is beyond you, I'd not try.
Reply 2 of 8, by EvieSigma
Yeah, it's really not something I even want to try, but I spent like two hours trying to find any of the BIOS update files for this motherboard and came up with only broken links and sadness.
Reply 4 of 8, by EvieSigma
Cobra42898 wrote on 2020-01-18, 19:13:
what does this board need to do that it currently doesn't? why is a bios reflash necessary?
I suppose it isn't strictly necessary, but since I'm on BIOS revision P04 and it goes up to P08, I would assume the newer revision provides some benefit.
Reply 5 of 8, by PC Hoarder Patrol
Is your motherboard on this list
https://web.archive.org/web/20021115164323/ht … efined&id=16571
If so then the file listed, 7511408.exe
BIOS update EA81510A.15A.0012.P09
Release Date: 12/5/2001
File Size: 654 KB
is available here
https://www.driverguide.com/driver/detail.php … 7c0e152094928a7
Reply 7 of 8, by PC Hoarder Patrol
No problem - I just follwed the trail from this old thread
Gateway 4000622 a.k.a. Intel D815EEA
and once I knew I was looking for P09 I found forum links to the support list and then the filename / file from that.
Hope it works OK 😀
Reply 8 of 8, by EvieSigma
Yeah, it works great. My CPU was working before but having the newest BIOS is always a good insurance policy for a CPU you aren't sure is supported.
