First post, by biohazardx9
HI all
Been lurking in Vogons but now registered.
recently rescued the compaq Deskpro EP 6350, well shall we say the motherboard part since the case was nowhere to be seen.
Luckily as this board is ATX form factor (minus the IO sheild), I have successfully transplanted it into another case. The front panel works as it should too.
The only thing I need to find its the utility floppies and drivers for it (I have the bios setup ones), which are a little tricky. it uses the intel 440BX chipset, and has a nice PII 350 slotted in. seeing as it has isa slots, my plan is to make it a DOS PC. Been watching a youtube channel called 'phils computer lab' (I believe he lurks in these forums). His site has helped me with the chipset driver at least. That script kit to practically get dos up for gaming was a nice touch too.
this board uses the Compaq Restore CD version 2.6 (or earlier?), that's a hard one to locate. If I ever see it I'll dump it to the internet archive or somewhere. Would Vogons drivers allow such a CD? (I did read the rules but wasn't sure on drivers)
Interestingly the BIOS boots my HDD but actually doesn't show its cyl/head etc... Windows sees it as a generic Disk...
Ideal platform for dos games though, my live card is currently doing the sound.
Any tips/pointers for this build?
