First post, by gladders
Hi all,
I downloaded the official drivers for this from the Dynabook website (it's for my old Satellite Pro 410), but while the first .exe executes, it doesn't seem to do anything, while the second .exe just craps out and says it can't run.
Does anyone have any experience of this?
Otherwise, the ESS688 is supposed to be compatible with the Soundblaster Pro. Does anyone know if it's alright to just install 3.1 drivers for the SBPro in place of the ESS688?
Thanks!
Reply 2 of 3, by Grzyb
Tried these? - http://www.vogonsdrivers.com/getfile.php?file … menustate=46,36
BTW: ES688 alone isn't enough for SB Pro compatibility, it must be coupled with an OPL3.
Reply 3 of 3, by thevdm
Strangely enough I installed Winodws 95 onto a Dell XPi CD last night with ESS688 sound, the drivers listed on vogonsdrivers.com didn't work for me, they installed but the device didn't work properly. In the end I managed to find a download of the DRV and VDX files so I could install it manually via device manager and it worked fine.
The drivers that worked for me are here: https://drive.google.com/file/d/0B2BOLB8yC3mn … HdCdHpRZVk/view
Gaming rig: Dell Dimension XPS T500 - PIII 500 - 288MB RAM - Voodoo3 3000 - SoundBlaster Live! Value - DVD-ROM - CD-RW - 3.5" 1.44 - 98SE & 2000 dual boot
A nostalgic pile of laptops from the late 80's to late 90s.
