First post, by Planet-Dune
Do they exist? I use SDCards for my testbench to quickly swap between operating systems. Got one for 98se, XP, 7 & 10. Now I would like to add some DOS. My smallest SDCards which I use for everything except Win7 & 10 is 16GB. I would only need 100mb or so. I looked around but can't find sdcards that size.. I guess 250mb would work as well (at least for 6.22, not sure about older). I know I can just partition a 16GB card to have a 100MB partition but it feels like a waste of the other 15.9GB 😀
Reply 2 of 10, by computerguy08
Small SD cards do exist. You can find them as small as 128MB in old digital cameras (or eBay). Anything smaller will likely be MMC.
Looking for a motherboard? You can find it in Ultimate Hardware 2019: http://www.win3x.org/uh19/motherboard/search
Join our UH19 Discord server here: https://discord.gg/HWWH7hsk2p
Reply 3 of 10, by Planet-Dune
mpe wrote on 2020-02-02, 22:40:
They do. They were just not called SD back then, but MMC.
I have as small cards as 16MB.
Interesting, but it seems those are not easily available and prices seem more expensive than SD. I buy my 16GB cards from Amazon DE for 4.99 euro each and free shipping to Belgium. Guess Ill just make a partition and pretend the other gb's don't exist.
Reply 4 of 10, by jtchip
Small capacity SD cards did exist, I have a few miniSD and microSD cards that are 128MB and they work fine as a boot drive for a Raspberry Pi (the root fs is mounted over NFS). They're not available new any more, you could try asking someone with an old digital camera or MP3 player.
Reply 5 of 10, by Mister Xiado
People like charging a mint for low-capacity memory cards on ebay, but they're there. I bought a 12MB memory stick for my Mavica camera, for like $20, but a 32GB MicroSD card is often less than half that. 😒
Reply 8 of 10, by imi
industrial cards can be had with 128, 256 and 512MB no problem, they're widely available, but they are not going to be cheaper than consumer 16GB cards :p but they do have the advantage of using SLC memory usually.
Reply 9 of 10, by derSammler
That's not really correct. MMC and SD are two different things with even different physical dimensions. It's just that early SD card slots were made backwards compatible with MMC, just like a DVD drive is backwards compatible with CDs.
SD cards started at 8 MB. Finding ones that small that are not written to death already could be quite hard, though. Smallest cards that are still common are 128 MB.
Reply 10 of 10, by jaZz_KCS
I found really old cards (below 1GB) to - most of the times - be incompatible with adapters a la SD2IDE, as their transfer speed is actually too slow to substitute for IDE transfers. The drive controller on my 386SX-16 luggable as well as on the 386-SX20 IBM PS/2 laptop hung up with "Sector not found" here and there, which could only be solved by using faster cards. Just a FYI.
