First post, by hyprthecat
Hey there I'm trying to get a 5.25 floppy drive working.
I have a few of them. But I am unsure if the boards being picky or what. It throws me a floppy disk error (40) error
I tried with both 3.5 and 5.25 but gets the error .
I have the pins set up right but if I run without the 3.5 should I set the 5.25 as the floppy disk A?
Reply 1 of 3, by Baoran
You need to tell detailed specs of the system. The reason for the drive not working might be elsewhere than in the drive floppy itself like motherboard, bios settings or a controller card.
Reply 2 of 3, by derSammler
hyprthecat wrote on 2020-02-22, 03:20:
Given that question, I'm guessing the drives are simply not connected correctly. So a few notes:
1. You always start with A:. If you have only one drive, it's A:.
2. A: and B: is determined by the position of the drive on the cable. End-connector is drive A:, middle connector is drive B:.
3. You must set the drive type correctly in the BIOS (DD/HD). This is very important for a 5.25" drive, since they differ in tracks making the seek test fail.
4. Older 5.25" drives can be terminated. On the cable end, the termination must be present, otherwise not.
From what I understand, you can't even get a 3.5" drive work. Make sure you solve this first before messing with the 5.25" drive.
