First post, by Synaps3
I am having a problem finding a decent PSU for my PIII system. It needs a 20-pin connector and a bunch of molex.
The problem with ebay is that nobody checks the caps and I've ordered multiple PSUs (even new ones) that had bulging and leaking caps.
Maybe someone on here sells PSUs or knows someone who checks them before sale?
Systems:
BOARD | RAM | CPU | GPU
ASUS CUV4X-D | 2GB | 2 x PIII Tualatin ~1.5 GHz | Radeon HD 4650
DELL DIMENSION XPS 466V | 64MB | AMD 5x86 133MHz | Number Nine Ticket to Ride
Sergey Kiselev's Micro8088 10MHz | 640KB | Trident VGA
Reply 1 of 2, by pentiumspeed
Get these rebuilt with good quality capacitors suggested by others and source them yourself and then if you have a local electronic repair shop, do it.
That's the suggestion. These days no choice there really.
Cheers,
Great Northern aka Canada.
Reply 2 of 2, by pentiumspeed
Secondly,
PIII does not need 5V heavy at all, In early days was common to see 200 to 300W loosely based on baby AT PSU design adapted for ATX standard.
Really, you don't need to worry much, get a new gold or bronze 80 Seasonic 550W with PFC PSU and it does have 20 pin plug which I use to test any ATX boards that are Pentium, PIII slot 1 and socket 370. As long as you don't have a card that needs -5V which is ISA audio cards.
Also I have older but still good Seasonic 380W waiting to be used. It was in other computers for a time in our household.
Only and very specific cases for two things:
If you have a sound card ISA with -5V pin on the connector (look it up on wiki to check against yours, even there is a gold finger make certain it is connected with a track or not?) and secondly especially Athlon slot A and Athlon XP socket 462 needed very fat current capacity 5V (over 30A). This is not needed if and especially if the socket 462 motherboard does have CPU 4 pin 12V plug next to the socket like any modern motherboard does.
No ISA slots motherboards then no need for -5V. If odd board still needs -5V, that is very rare as this usually for high quality serial ports.
Cheers,
