First post, by Nitroraptor53
- Member
Hey Guys! I needed to know where I could get l2 cache modules (8 Chips) totaling 1024k? I'm pretty sure the board supports it, But only one way to find out! ; )
Look for IS61C1024-15 on eBay.
But be prepared to order more than you need as many of these chips will be dead on arrival.
Depending on your motherboard you might also need to upgrade 9th tag chip or 10th dirty tag chip.
and fakes. be prepared for them not to be the speed rating they are marked at.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
I got mine from utsource.net - you can also try alibaba or aliexpress
In my 486 it made little difference upgrading from 256kb to 1mb, beyond the number on the POST screen. Maybe if I was running 64mb of RAM or something equally ridiculous for a 486, but those big SIMMs are probably harder to find than the cache chips.
Nitroraptor53 wrote on 2020-02-26, 17:36:Hey Guys! I needed to know where I could get l2 cache modules (8 Chips) totaling 1024k? I'm pretty sure the board supports it, But only one way to find out! ; )
Which mainboard?
Pictures?
Threads are boring without pictures 😀
DonutKing wrote on 2020-02-26, 20:57:I got mine from utsource.net - you can also try alibaba or aliexpress
I...don't know what you mean? 16MB 72pin SIMMs are super easy to find. Now, 64mb of 30pin RAM, that would be expensive.
Ridiculous is 128MB RAM in my Macintosh SE/30 (1989 system).
64MB RAM wasn't that uncommon in 486 days if you were doing stuff like DTP in Aldus Pagemaker or QuarkXPress.
mpe wrote on 2020-02-26, 18:55:Look for IS61C1024-15 on eBay.
Thanks! Found some. I'm upgrading the living sh* out of an IBM PS/1 which will have 1024k Cache, Pentium 63 OD, 64mb RAM, XTIDE and will update the bios. Unfortunately, my manual does not specify max Cache supported, so wish me luck : )
mpe wrote on 2020-02-26, 22:40:Ridiculous is 128MB RAM in my Macintosh SE/30 (1989 system).
How on God's Green Earth did you get that much RAM on an SE/30? Accelerator Card?
Nitroraptor53 wrote on 2020-02-26, 23:21:mpe wrote on 2020-02-26, 18:55:Look for IS61C1024-15 on eBay.
Sorry to say, but that's nonsense.
You have to check at least if your cache sockets are 32pin.
mpe wrote on 2020-02-26, 22:40:64MB RAM wasn't that uncommon in 486 days if you were doing stuff like DTP in Aldus Pagemaker or QuarkXPress.
AKA 'edge case' 😀
CoffeeOne wrote on 2020-02-26, 23:24:Nitroraptor53 wrote on 2020-02-26, 23:21:mpe wrote on 2020-02-26, 18:55:Look for IS61C1024-15 on eBay.
They are!
I forgot... can we cuss on here? LoL
Nitroraptor53 wrote on 2020-02-26, 23:35:CoffeeOne wrote on 2020-02-26, 23:24:Nitroraptor53 wrote on 2020-02-26, 23:21:Thanks! Found some. I'm upgrading the living sh* out of an IBM PS/1 which will have 1024k Cache, Pentium 63 OD, 64mb RAM, XTIDE and will update the bios. Unfortunately, my manual does not specify max Cache supported, so wish me luck : )
You have to check at least if your cache sockets are 32pin.They are!
Lol, do you have a prove for that?
2055—Cache MemoryWarning:Memory cards are sensitive to static discharge. See “HandlingESD-Sensitive Parts” on page 4-47.Cover (2005)Adapter Card(s) (2035) if applicableRiser Card (2045) if applicable.Note: Run the Configuration Utility after adding or removing cache memory.If the system board has cache memory modules already installed, the com-puter has 128K of cache memory. Upgrade to 256K by adding memorymodules as follows:Bank 2Add four 28-pin modules: 32K×8, 25 ns SRAM.TagReplace existing module with one 28-pin module: 32K×8,20 ns SRAM.If you are installing cache memory in a board with no cache memory previ-ously installed, install 128K or 256K as follows:Bank 1Add four 28-pin modules: 32K×8, 25 ns SRAM (for 128K or256K).Bank 2Add four 28-pin modules: 32K×8, 25 ns SRAM (for 256K).TagAdd one 28-pin module: 32K×8, 20 ns SRAM (for 256K)or8K × 8, 20 ns SRAM (for 128K).
Yes, we need to really wish you good luck to put the 32pin chips into the 28pin sockets.
Have fun.
CoffeeOne wrote on 2020-02-27, 00:03:" 2055—Cache MemoryWarning:Memory cards are sensitive to static discharge. See “HandlingESD-Sensitive Parts” on page 4-47.Cove […]
Yes, we need to really wish you good luck to put the 32pin chips into the 28pin sockets.Have fun.
What's that?
You guys might remember my post from yesterday. Well, I miscounted. My PS/1 2168 has 28 pin DIP sockets, not 32 pin... So are there any boards that would let me put those chips on an ISA board?
Picture?
How much cache does the system support?
How much does it currently have?
How many sockets does it have?
Nitroraptor53 wrote on 2020-02-26, 23:23:mpe wrote on 2020-02-26, 22:40:Ridiculous is 128MB RAM in my Macintosh SE/30 (1989 system).
Regular SE/30 has 8x 30p SIMM slots. Populate them with 16MB SIMMs and you get 128MB. I did the same when I briefly had an SE/30 back in the 00's.
