Video Memory
First post, by cookertron
I have a CL-GD5428-80QC-A video card built into the motherboard. How can I find out how much video memory it has? Also there are 6 chip sockets next to it which I'm assuming are for video memory expansion but I can't find any information relating to the chips needed to populate the sockets 😒
A bit of research suggests the GD5428 has 2mb of ram but I'd like to be able to verify that.
Thank you for your time.
Anthony
EDIT: oh crud, I've just seen there's a video card section in the forum!
Model: Viglen Contender Professional (4SX25) CPU: AMD AM80486DX2-66 Chipset: ALI M1429G (9414) Video: CL-GD5428-80QC-A BIOS: Phoenix DragonBIOS 486 ISA (1993) Sound: Sound Blaster 16 (CT2230)
Reply 2 of 5, by cookertron
derSammler wrote on 2020-02-26, 20:07:
...the CL VGA chips and was normally not used with 2 MB.
On closer inspection of the info on the 5428 it says it supports "up to" 2mb 😳
I'd still like to know if there's a way of finding out the amount of video ram though.
Could there be something in windows 3.1 that'll reveal all?
Reply 4 of 5, by mpe
The 5428 can be configured with either 1MB or 2MB DRAM. If you have any free sockets on your card you have 1 MB. If they are all populated you have 2MB.
The only difference the 2M upgrade will make is enabling of the following three extra resolution modes:
1024 × 768 × 32K (interlaced)
1024 × 768 × 64K (interlaced)
1280 × 1024 × 256 (interlaced)
They are all interlaced resolutions due to the shitty DAC in these chips so this is not actually useful for anything. There are no other benefits. You won't get even 800x600x16M as some other 2M cards can do.
Blog|NexGen 586|S4
Reply 5 of 5, by cookertron
mpe wrote on 2020-02-26, 22:29:
The 5428 can be configured with either 1MB or 2MB DRAM. If you have any free sockets on your card you have 1 MB. If they are al […]
That pretty much answered my next question 🤣
Thank you for your sharing your time and knowledge!
