First post, by Ozzuneoj
- Oldbie
I got a good deal on a Sapphire Radeon HD3850 512MB AGP card last month, with the intent of using it my newest AGP system. The system is running an EPoX 9NDA3J nforce 3 Ultra motherboard with the latest beta BIOS and an Athlon 64 X2 4200+. Everything works fine with a 6800GT, but with the HD3850 I simply get no display at all. The system seems to post properly and I get no error beeps, but all of the video outputs are giving no signal. The power supply is a Seasonic 550-HT with 30A on the +5v rail and 4x 18A 12v rails, so that should be plenty. I've tried using the PSU's built in 8pin PCI-E power connector (that's what the card uses) as well as a 2-6pin to 1-8pin adapter just in case it was a rail balancing issue. The little red LED that turns on when the card has insufficient power does not come on unless I actually disconnect the power cable, so it seems to be getting the power it needs.
I can drop the card into my older ABIT NF7-S 2.0 nForce 2 Ultra 400 system (with the same model PSU) and it works fine, so it doesn't appear to be dead.
Any idea what could be going on here? I know that late AGP cards can be finicky, but it seems odd that one of the last native-AGP boards wouldn't work with a GPU made for late AGP motherboards, and yet a slightly older board works perfectly fine with the same card.
