First post, by Carlos S. M.
Almost 4 years ago, i made threads about LGA 775 w/ AGP and socket 478 w/ PCIe boards, but haven't looked looked on the AMD side and decided to do more research and make it's correspoinding threads as well
This time is about AM2 motherboards with AGP slots, ASRock Socket 754 and 939 boards with the upgrade card option are also listed as well, might be updated over the time
OS Support for these boards:
Windows 98 SE/ME (most of the boards supports/can work with Windows 9x)
Windows 2000
Windows XP
Windows Server 2003
Windows Vista/2008 (Limited support in nForce 3)
Windows 7/2008 R2 (Limited support in nForce 3)
Windows 8/2012 (Limited support in nForce 3)
Windows 8.1/2012 R2 (Limited support in nForce 3)
Windows 10 up to version 1511 ( Limited support in nForce 3, 1607 and newer dropped AGP support making 10 unusable on these systems)
Linux
Legend/Notes:
(1) This board only supports Athlon 64 CPUs
(2) This board only supports Athlon 64 and Phenom CPUs
(3) This board supports Athlon 64 and Phenom I/II CPUs
nVidia nForce 3 250:
(3) ASRock AM2NF3-VSTA
(3) ASRock ALiveDual-eSATA2 (ULi M1695 paried with nForce 3 250 for AGP support)
(1) ASRock K8Upgrade-NF3 (w/ AM2 Upgrade card)
(1) Biostar NF3 250 AM2
(1) Gigabyte GA-MF3
SiS 760GX:
(1) ASRock K8Upgrade-760GX (w/ AM2 Upgrade card)
ULi M1689:
(1) ASRock K8Upgrade-1689 (w/ AM2 Upgrade card)
ULi M1695/M1567:
(3) ASRock 939Dual-SATA2 (w/ AM2 Upgrade card)
(3) ASRock 939Dual-VSTA (w/ AM2 Upgrade card)
VIA K8M800:
(1) ASRock K8Upgrade-VM800 (w/ AM2 Upgrade card)
(1) Biostar K8M800 Micro AM2
(1) MSI K9MM-V
Reply 1 of 3, by frudi
I was just in the process of looking for an AM2 board with AGP a few weeks ago, I could have used a nice concise list like this 😀
I ended up getting a trio of ASRock's AM2NF3-VSTA boards, sold as defective on ebay and explicitly described as not working at all. I figured I'd be able to fix one of them with the spare parts from the other two; or maybe if I was really lucky, one of them wouldn't even be defective in the first place. But then all three turned out to work just fine, so no idea how the seller was testing them 😀. Anyway, can confirm this particular board works mostly fine with Windows 98SE and Windows ME, using nvidia's unified nforce drivers. I'm still experiencing some stability issues, mainly in the form of windows hanging during boot up or shutdown, but that may simply be down to me using 1 GB of memory for now (still waiting on some lower capacity DDR2 sticks to arrive).
Reply 2 of 3, by ole smoky2
I have the Biostar K8M800 Micro AM2 board. Bought it new back in the day from Newegg as a budget computer for my son. Still works great today running Linux Mint with a Athlon 64 x2 4200 cpu and Ati 1650 agp card.
Reply 3 of 3, by dionb
frudi wrote on 2020-03-02, 13:16:
I have one as well. with a PhenomII-X4 and 4GB of RAM, running Linux. It's quite a bit slower than I would expect for the specs (possibly limited Linux nF3 chipset support?), but otherwise rock-solid.
