First post, by jasa1063
- Member
I recently put together an Athlon XP 3200+ retro build using an ASUS A7V600 motherboard with a VIA KT600 chipset. I have had some stability issues with DDR 3200 memory running at 400 Mhz. It runs fine a 333 Mhz. It currently has the last production BIOS 1008. There is a beta BIOS 1009 on ASUS's website and was wondering if upgrading to this version would help with memory compatibility. I cannot find any release notes on this version, and I am hesitant to upgrade the BIOS to this version in case it causes problems. Does anyone have experience with this BIOS release and if I were to upgrade can I install the previous BIOS version if necessary?
Thanks!
