First post, by Scythifuge
Greetings,
I replaced my CT2760 that died (detected at address but hangs at IRQ) with a CT3990 because it was a good deal. I have set it up with the drivers I downloaded from Vogons and it works great.
However...
I have been trying to connect a SATA SSD to this machine (socket 5, Pentium 133Mhz) in order to store ISO images for mounting with a drive emulator in MS-DOS. From what I have read, the IDE interface on theCT3990 isn't limited to optical drives. I have tried connecting both the SATA SSD (with a SATA - IDE adapter) and an optical drive to the CT3990 IDE interface. I cannot seem to have either drive detect. I also cannot get my motherboard to recognize the SATA SSD when it is connected to the secondary IDE port on the motherboard. The adapter was an ebay purchase, and I have no other way to test it to see if it has any issues.
My questions are:
1. How do I use the IDE interface on the CT3990? A special driver, and/or special lines in config.sys or autoexec.bat?
2. How do I successfully use a SATA hard drive in an old machine?
3. Unrelated, but I have a Pentium 166 MMX cpu that I may want to replace the 133 (appears non-MMX) with. Do these older processors need thermal paste? The mobo I am using came with the 133 presintalled with just a heatsink. I also don't see an easy way to remove the retention clip, unlike modern cpus.
It is frustrating because I used to love tinkering with this stuff and I even successfully installed a cdrom drive on my previous AWE32, but since my motorcycle accident, things are hazy and I can't recall how I did some of these things (also relearning how to optimize my start up files - I used to have no problem getting around 620k or so, but now I can't seem to get past 570k or so.)
Scythifuge
Reply 1 of 9, by Predator99
I dont think you are able to use a Hard Drive on the IDE Port of a CT3990 under DOS because it needs to be initialized by a driver first. And this driver only support CD-ROM drives.
You can however connect a IDE-HD to Soundcards which are configured with Jumpers and boot from them via XT-IDE.
Correct me if I am not right 😉
Reply 2 of 9, by Scythifuge
Predator99 wrote on 2020-03-11, 19:54:
I wasn't sure, as it just says "IDE" and I thought I read somewhere that it was for any device, though I can't get it to recognize the optical drive. There is an INF file for the IDE port on the driver CD, and I reinstalled the drivers with the cdrom connected to see if it detects it that way and sets up the start up files.
Another issue I forgot to mention is that I keep changing the midi port to 300 with CTCU (I have an MPU-IPC-T in here using 330,) but DIAGNOSE keeps setting it back to 330.
Reply 3 of 9, by derSammler
You can attach a hard disk to it and no driver is needed, but the port is normally IDE channel 3 or 4, so no BIOS support. DOS won't see it. You would need to run Win9x.
XT-IDE supports IDE channel 3 and 4, however.
Reply 4 of 9, by Scythifuge
derSammler wrote on 2020-03-11, 20:49:
I'm thinking of moving to something newer. I have a Pentium II system lying around, and I may just turn that into a DOS/WFW311/Win98 box and use Moslo Deluxe, and try to put multiple sound cards in it such as a Live!, AWE32, and the MPU. I would put my SCC-1 in it instead of the MPU, but I could never get it to talk to my MT-32.
If I just bite the bullet and go newer instead of trying to stay period correct as possible for speeds (I don't mind the QoL components like CF-IDE, etc,) I think that I would have less frustration, and have the best of multiple worlds. I am getting close to using 86box and DOSBox exclusively, due to the frustration of working with these older machines. It sucks, because I used to really love tinkering with PCs!
Perhaps am Asus P28 mobo will have a better chance at seeing the SSD, though I still need to solve how to use the AWE32 IDE, and getting it to save the midi address at 300.
Reply 5 of 9, by SirNickity
Not sure newer will help with some of these issues. The problem is just that DOS was so %@^$ stupid, and had no real architecture for hardware that didn't exist on an 8088. Everything had to be hacked in by drivers that intercepted software interrupts and lied to DOS. If a driver doesn't exist for a specific purpose (like enumerating hard drives on a tertiary IDE port) then the Pentium itself isn't the problem.
An easy workaround would be to just run WIn95 and do everything in a DOS prompt. That way, Windows can load your drivers, provide ISO mounting, SB emulation, MIDI, and so on and so forth.
Reply 6 of 9, by Scythifuge
SirNickity wrote on 2020-03-11, 23:37:
I'll need an optical drive for DOS. I have been sitting here thinking about what I want to do. I had a desire to play some does games a couple of weeks ago, and have been trying top solve these issues ever since. I remember having a fairly large HD on my old P3. The idea is to avoid having multiple builds and having to swap discs. I can't find any information on getting this cdrom to work with the AWE32, and I don't know if Win9x will see any large drives since the bios doesn't.
This all began because my 486 died...
Reply 7 of 9, by Disruptor
Scythifuge wrote on 2020-03-11, 19:48:
Which drive emulator do you use?
However, even when you get this solution to work:
You will have activated a hand brake on both rear and front wheels then:
ISA-Bus + PIO-Mode
You won't get much more than 2 MB/s with a SSD that usually can deliver much more than 60 MB/s.
You'd better connect your SSD to one of the motherboard's ports. Usually SATA to PATA converters can be jumpered as Master/Slave/CS too like normal PATA drives.
When you do not like to boot from the SSD you probably do not need to configure the SSD in BIOS. Windows 9x may detect it without the BIOS. Be sure it is partitionend and formattet properly. DOS 6.22 may have a problem with disks greater than 8,4 GB. You may try to increase the partition size from 8 GB to 32 GB to 128 GB. Remember the 48-Bit-LBA limit at 128 GiB = 137 GB.
Reply 8 of 9, by SirNickity
Disruptor wrote on 2020-03-12, 09:33:
ISA-Bus + PIO-Mode
Still... that's roughly equivalent to a 12X CD-ROM. For any DOS application, that's pretty darn fast -- especially when you consider the near-zero access time.
Reply 9 of 9, by Scythifuge
Which drive emulator do you use? […]
ISA-Bus + PIO-Mode
I plan on trying to use SHSUCD (I think that that is what it is called.)
I'm using the SSD because it was an older 480gb that I had lying around. I located a 1tb mechanical SATA drive, and I can't get that to work, either. I have tried both the CT3990 and the secondary IDE port.
I tried using fdisk from Windows 95 OSR2, and it does not see the drive.
