First post, by TheAbandonwareGuy
- Oldbie
So I'm moving all my GPUs and cards from standard sandwich bags (a hold over from an impromptu move, which is a hold over from the great mouse invasion that made cardboard boxes a no go) to the pink Anti-Static bags. I'm reading here (should have googled this BEFORE I ordered bags. Oh well) that Anti-static bags only prevent the build up of static electricity, and are incapable of storing a charge. They (unlike ESD/Static Shield bags) do NOT provide ESD discharge protection. My logic is that means the only possible sources of ESD are the card itself and my hand moving it into and out of the bag, and I store these in small plastic totes, with 2 to 7 of these bagged cards stacked (I'm using 12x15 bags, so each one has decent amounts of padding. I also like how pink bags have a nice cusioning effect) depending on the size of the card. The boxes are stored on a wooden shelf, stacked 4 high. So I have 3 layers of static resistance in the way of wood, plastic, and then anti-static pink bag. I'm paranoid and don't want even 1 single card failing on me in storage due to ESD so I'm going to order static shield bags and put them inside the pink bags.
I've also heard most modern components are basically immune to static. Is this true in your experience, when does this become true? I figure its probably true of cards 2000 and up if its true.
What are you storage practices like? Am I an idiot?
https://www.youtube.com/channel/UCuFY6ZVlYOXA12tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF2 Ultra 64MB|CT4620
#Bernie2020 #FeelTheBern
