First post, by LewisRaz
Hello all.
I was tinkering with this pc last night. (Swapping around some GPUs)
After I had finished I put the system back together and turned it on.
The system posted as normal but all the white text was purple. Not like when a VGA cable is loose, actual purple with a few words still in white.
After the post finished the PC speaker made some awful sounds and I shut the machine off.
Now it refuses to post. Not even any error beeps.
I have tried:
Different known working ram.
Different known working CPU (both 100 and 133mhz and slot1/slocket)
Different GPUs - AGP, PCI and even ISA.
All non essential parts have been unplugged (sound cards drives etc.)
I have studied the board in detail and cannot see any burned or damaged components.
If a modern machine still displayed this behaviour after these checks I would likely condemn it but I dont want to write off this board that easily!
Does anyone have any suggestions?
My retro pc youtube channel
Reply 2 of 9, by LewisRaz
Oops. I should have mentioned I did a clear cmos.
I have read through the documentation and cannot find any way to manually use the backup bios. It should start automatically in case of the main bios failing.
Reply 3 of 9, by psybyrd
How do the Capacitors look? Gigabyte used some pretty terrible ones in this era. However sometimes you get lucky and have one with Sanyos. Also check your power supply. I would remove everything including the cmos battery and leave it sit (for a few hours). Seen many come back to life after doing this. Hope this helps
Reply 4 of 9, by LewisRaz
psybyrd wrote on 2020-03-13, 13:48:
The caps look pretty good to be honest! Although I am aware they can go bad without any visual signs.
I can try another PSU. Might try that tonight in fact. This machine has sat for some time without power lately as I have been testing other machines in its space.
Really would like to get it going again but if not ill be back to AMD for my "fast" w98 system.
Reply 5 of 9, by LewisRaz
So after trying a different PSU I stripped the motherboard and and fit my athlon system back in.
Before I put the P3 away for a while I decided to fire it up on a test bench and of course it booted right up..!
It did provide this error "main bios wide range protection error"
Has anyone encountered this before?
Reply 7 of 9, by LewisRaz
quicknick wrote on 2020-03-13, 21:02:
Yes. 😀
Thankyou for finding that! some helpful reading. I think that my main bios chip is on its way out. I have had random faults with this board for some time!
It also only booted the one time while I made the last post and now fails to power on at all... One for another day now.
Reply 9 of 9, by LewisRaz
SETBLASTER wrote on 2020-03-13, 22:47:
@LewisRaz did you buy the motherboard fully with box, manual and cd-rom drivers? do you happen to have the original CD for it? […]
if you do, can you share an iso image?
thanks
Sorry I got the board from ebay as cpu/board and backplate
