First post, by th1r5bvn23
The P3B-F v1.04 is the only 440BX motherboard I have. I'd like to use it as a sound card test platform, so I need to install SB-Link header. It seems that apart from 5-pin header, some resistors or capacitors are also needed. So, how can I install SB-Link header and related components on this motherboard? Thanks for your help.
AMD K6-2+ 500, FIC PA-2013 2.0 (1MB cache), 128MB SDRAM PC100, Voodoo3 3000 AGP, Labway Yamaha YMF719B-S with NEC XR385
AMD Athlon 64 3000+, ECS K8M800-M3, 512MB DDR 400, GeForce FX 5200, SoundBlaster Live! SB0060
Reply 1 of 2, by The Serpent Rider
Everything SB-Link does can be done in software. At least when it comes to 440BX platform. So it's kinda redundant.
Reply 2 of 2, by th1r5bvn23
The Serpent Rider wrote on 2020-03-18, 20:43:
I'd like to test AWE64D, which is only DOS-compatible when using SB-Link.
