Reply 740 of 831, by Mumak
- Oldbie
andunn wrote on 2021-10-21, 09:00:Sure, here it is.
Thanks. I tried to adjust reporting of the FPU to show IIT4C87DLC and proper clock. Can you please try this build and let me know the result:
Hi Martin,
Just out of curiosity, I was trying HWiNFO 4.6.4 (I know it's too old, don't ask!) to compare to 6.1.3 on the CX486DLC CPU (well actually I have the TX version but they are basically the same CPU).
For the CPU itself HWiNFO 6.1.3 shows the correct and complete name.
But for the FPU, HWiNFO 4 shows the TM text on the FasMath name but 6.1.3 does not. Is this as expected? The FPU has TM in its name, for sure. It's even written on top of the ceramic package.
Also on version 4 the name of the BIOS is completely spelled as Microid Research while the new one is trimmed down. Again, is it as expected?
I have one additional question: regarding the differences in CPU vs. FPU frequency. I have noticed differences with the 386/387 pair as well. Is the frequency display inferred from some kind of software algorithm? And if so, can't it be made more accurate? It's not an issue by itself. But practically in these kind of systems, the CPU and FPU all run on the same CLK2 signal.
Thanks,
Alex
TX486DLC / 40 MHz | 32 Mb RAM | Tseng Labs ET4000/W32i with 2 Mb RAM | ISA I/O Interface | ISA Audio Interface | 3.5" & 5.25" FDD | 4 x 512 Mb CF | Intel EtherExpress 16
ALEKS wrote on 2021-10-31, 11:19:Hi Martin, […]
Hi Martin,
Also on version 4 the name of the BIOS is completely spelled as Microid Research while the new one is trimmed down. Again, is it as expected?hwinfo4.jpg
Thanks,
Alex
The trademark symbol has been removed in later versions, it doesn't make much sense to display this.
I will update HWiNFO to show full "Microid Research" BIOS manufacturer.
FPU frequency is determined by measuring time required to execute a batch of FPU instructions. This requires exact knowledge of FPU present and how many clock cycles the instruction takes. There's no other precise method available and if the FPU is not properly recognized or the amount of clock cycles not exactly known (which is often the case due to lack of detailed documentation), the result won't be correct.
Mumak wrote on 2021-10-21, 09:39:I tried to adjust reporting of the FPU to show IIT4C87DLC and proper clock.
Those seem to be fixed, see results attached.
andunn wrote on 2021-11-01, 19:27:Mumak wrote on 2021-10-21, 09:39:I tried to adjust reporting of the FPU to show IIT4C87DLC and proper clock.
Looks great, thanks!
Where is the "computer name" string read from? I have seen that only some mainboards report such a name. Is it an identifier within the BIOS? Or a specific BIOS function that returns this string?
Thanks,
A.
ALEKS wrote on 2021-11-02, 15:46:Where is the "computer name" string read from? I have seen that only some mainboards report such a name. Is it an identifier within the BIOS? Or a specific BIOS function that returns this string?
Thanks,
A.
That depends on system, there are several methods used. In most cases it's a string read from BIOS, in a few others it's based on some IDs or functions.
Mumak wrote on 2021-04-05, 17:57:If there would be a demand for an 8086-80286 version I can start work on such project.
Hello, it would be very interesting for these old machines.
I'll add: +1
Thanks for your efforts, the 386 version is still awesome.
IBM Ps-2 model 30 (8086 / Nec v30) - Tridend 8900d 1024 ram - floppy 720 kb - HDD 20 Mb (KO) - XT CF-Lite v4.1 with 1GB CF Microdrive IBM
FlashCade wrote on 2021-11-21, 14:01:Hello, it would be very interesting for these old machines. I'll add: +1 Thanks for your efforts, the 386 version is still aweso […]
I'll add: +1
I have just released HWiNFO16 for 8086-286 systems: Introducing HWiNFO16 (for 8086/88/186/188/286)
Any feedback is welcome.
Mumak wrote on 2021-11-23, 13:21:I have just released HWiNFO16 for 8086-286 systems: Introducing HWiNFO16 (for 8086/88/186/188/286)
Nice! I will be setting up at 286 sometime in 2022.
Awesome. I'll try to give it a test run on my 286 over the weekend.
Released version 6.2.0 which includes HWiNFO16 v1.7 too.
Check initial post for download and release details.
Is possible to merge 286 a 386+ version to one and on the fly detect on which machine is HWinfo running and run right code?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
ruthan wrote on 2021-12-04, 11:19:Is possible to merge 286 a 386+ version to one and on the fly detect on which machine is HWinfo running and run right code?
HWiNFO (386) is already requiring a lot of system memory to fit, yet it's possible to keep it by using the 386 (32-bit) instruction set which reduces size. Including 286-capable code would result in a significant increase in size.
Still it seems possible in theory make some starter .exe to detect on which machine is program running and after than run 386+ or 286 exe.. Only disadvantage which i see is bigger program size.. Of course with more clever method (use only 286 code for start detect machine and after by some if and else use or not use some 386 instructions.. )
It would be possible to create a launcher that based on a quick CPU check would run either HWINFO or HWINFO16.
But duplicating the same methods using 286 and 386 set in the same program doesn't make much sense. And there would have to be a 8086 version anyway...
Its not possible make 386 + 086-286? We would need 3 versions?
HWiNFO is 386+, HWiNFO16 is 8086-286.
Hey Mumak,
some years ago I decided to mirror HWiNFO v5.5.5 (in the tools section of my website -> soggi.org - tools) as development had stopped back then and I was afraid that it will vanish from your website - I always want to preserve great tools (and many other things).
Now where you restarted development I just want to ask, if it's still OK to mirror HWiNFO for DOS / HWiNFO16!? There will also be a link to this thread to reach the ongoing support.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - talent borrows, genius steals...
soggi wrote on 2021-12-06, 15:02:Hey Mumak, […]
Hey Mumak,
kind regards
soggi
Of course, feel free to do so 😀
