First post, by Nemo1985
Hello, i'm looking for advices about building a 486 build with the UMC U5SX 486-40.
I've tried to use a vlb motherboard and overclock the cpu to 50mhz but it's a no go, the system doesn't boot.
I also have an Asus PVI-486SP3 but it probably won't support the 50 mhz fsb since it lacks the proper pci divider, other than that I have the Biostar MB-8433UUD rev 2, that doesn't support UMC cpus.
I was thinking about using a Shuttle HOT 433, the cpu shouldn't have particular issues to be overclocked to 50 mhz so it's all a matter of memory and cache.
Any advice is more than welcome.
Thanks in advance.
Reply 1 of 2, by derSammler
What's your actual aim? VLB is already flaky at 40 MHz, let alone 50 MHz. And why do you want to overclock the CPU, too? If you want to build a very fast 486, the UMC CPU is not suitable for that. And if you just want to build an UMC-based 486, go without overclocking. Even if you get it working, the additional wait states you need for a 50 MHz system will eat up any speed gain you get from the higher CPU clock.
And, by the way, while the UMC stays cold during operation, it does not overclock very well. None of my 33 MHz ones run at 40 MHz and even if they would, what't the point anyway? If we want more speed, we can use faster CPUs.
Reply 2 of 2, by Nemo1985
I like the umc cpu because despite being a common SX cpu it was faster (clock to clock) than intel\amd counterparts.
I already have a fast 486 build with amd 5x86 cpu, I just want to try overclock the umc cpu, since the vlb experiment failed I'm looking for some advices about what motherboard to use (I suppose pci would be better) to be able to achieve the 50 mhz.
