First post, by Swiego
If my one or two devices connected to an IDE cable are jumpered explicitly for Master/Slave, does it matter which connector (in a 3-connector IDE cable) is connected to the motherboard? Could it be either end? Better yet, the middle connector?
Secondary question, does the answer to the above question(s) change depending on 40- vs 80-pin?
