First post, by Jackhead
I managed to find a MPU-401 breakout box with a Low Tech MIF-IPC rev2 interface.
But i need the connection cable.
Anyone a suggestion maybe a link to a cable i can use? I think it musst be full 25pins wired 1:1 ?
So i cant use a seriell db25. Maybe SCSI 1 cable? But i found not really one on ebay..
regards
Chris
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 1, by sndtst
According to this scan of a Roland document (http://www.symphoniae.com/synth/Roland/MPU401 … F-IPC_Cable.pdf) the cable is a direct pass through of all pins with the exception of pin 13 and 25 which are described as " straight across and also crossed wired". I only have half of an original cable but looking inside I don't see any cross wiring and looking at the circuit of the IPC and the MPU-401 and it looks like tho use pins are ground pins. I just tested my MPU-401 and MIF-IPC with a 25 pin straight through serial cable and it works perfectly 😀
A Sound Test for as many games as I can find at SNDTST.com
