First post, by Mentalbass
I've got an HP Vectra P3 500mhz 512Meg RAM. It works like a charm. Just can't figure out why the CD-rom and CD-burner only read original CD's, like audio or software.
They both won't read burned discs.
The CDRom drive and burner are original HP. Is it timeperiod of those drives, there aged, why it won't read modern burned discs?
Is there a way to change this, without swapping the drives for newer ones?
Thanks!
Rise of the Triad
Reply 1 of 2, by brian105
Probably means that it's only a CD-ROM reader, so burned CD-R's won't work. A bit odd, considering my 1998 Compaq supports DVD-ROMs and CD-R's as well.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 2 of 2, by Mentalbass
brian105 wrote on 2020-04-24, 17:02:
Removed the drives. Burner dates from 98 and the cd from 99. Possible theyre worn out.
I bought replacements, an hp dvd burner and hp dvd reader drive.
So it was strange to me that original drives didn't read them. Think its aged and done for.
Rise of the Triad
