First post, by auron
looking through the readme of adaptec's DOS driver package, the aspidisk.sys driver is mentioned only for use with controllers that do not have a BIOS, and if a BIOS is present, of course hard drives run fine without any driver under i13h control in DOS. however, i've seen vague remarks on the internet that using a driver (for adaptec, presumably said aspidisk.sys) can actually improve HDD performance, but in what way would a driver operate differently? the adaptec controllers generally require busmastering, so as i understand it this should be performed even when using i13h.
for windows 95, naturally the VXD drivers that are installed along with the OS are needed for 32-bit file/disk access, otherwise it would just be running 16-bit MS-DOS compatibility mode. but for real mode DOS, i'm not seeing where the big speedup should be coming from when using a driver.
