First post, by ppsh41
Someone asked me for the setup disk (aka user disk) to configure the Olivetti PCS-44/C. I put it here for the benefit of those who need it, along with an extract from the service manual.
One disc is specific for the M4-40, PCS-44/C and Familia 2 models and is in Italian, and that's what I used.
The second disk is specific to the PCS-46/C and is in English, I put it here for comparison.
It may be that both disks are fine, since the PCS-4xC / M4-xx are very similar, if not the same.
The setup software is originally contained in a hidden partition called "system region", and can be invoked at boot with a combination of keys (alt-u, alt-ctrl-u, I don't remember exactly). The user disk allows the configuration of the machine and also to re-create the system region partition if you change the HD. The HDs compatible with these machines are few (read the service manual). Anyway, I have successfully used an old version of MaxBlast to run a 512 MB compact flash.
Below is my motherboard, assy: BA2033, type: T.1
