First post, by omega9380
Hey all,
I picked up a second Gotek SFR1M44-U100 to have a spare and was flashing it with FlashFloppy. I use a CH341A USB programmer in TTL mode, STM32FLASH on Pop Linux. Just like my first Gotek (which works great), I ran the commands as per FlashFloppy's wiki:
# sudo stm32flash -k /dev/ttyUSB0
# sudo stm32flash -vw FF_Gotek-v0.10.hex /dev/ttyUSB0
The first time I did this I didn't realize that my CH341 had a flaky solder job on the USB port. A bumped laptop later, my Gotek failed the flash. Now when I run the -k swicth on stm32flash, it successfully unlocks the chip for programming (no errors), however when I then try the -vw command, I get 'Failed to init device' every time.
I've since reflowed the USB port on my programmer to fix that issue. My question to you is, can I save my extra Gotek? Is there a way to fix a failed FlashFloppy flash? Help!
