Currently as of now these days from long searches, there is currently no available PSU for compaq deskpro M series. I need that pinout so others can build adapter to use ATX PSU on it. If I have a PSU for deskpro M series, this will be a golden time even loaned one in semi-working, broken state or working state is very essential as what I see, there is pretty large number of Deskpro M owners with their power supply potentially bound to fail one day and to make adapter just for this will be much nice.
The Deskpro M power supply is very, very special design and I need to document this very carefully:
I suspected that may be a signal loopback so PSU knows is complete circuit is made from the both slot board and I/O board is connected together to power up. Conjunctive theory. I verified and this need to be documented fully since that because -5V path goes through I/O board from PSU connector first, then back out to slot board to the EISA slots pin for -5V, I had to plug both slot and i/o boards together to get -5V path made complete!). How I know, I recently bought a set of boards to make a working Deskpro M computer on bench but without PSU, I'm stumped on these unknown 3 pins left to document. Oh, there is no LED connection since PSU is not butting against front panel like my Deskpro 386/25e motherboard is (PSU pinout already documented except two (easy!), just matter of guessing which one is power good pin therefore know other pin LED output through PSU's board to illuminate hard drive activity LED), 386/25e PSU is full length PSU front to back with two LEDs in the PSU for power and hard drive activity.
Second, one of unknown pin has to have a "power good" signal that is held low (forced low held the reset line in the computer's board, then pulled up to 5V allows computer to boot. This is still present to the current time in all computers to the day even the Intel new 2020 ATX 10pin 12V design. That was IBM idea first started with PC 5150, the circuit to signal power good comes from internal PSU monitoring 4 voltages 5 and 12 both minus and positive are all correct then few milliseconds later then power good is enabled, thus releasing reset circuits allowing motherboard to run.
Cheers,
There are 3 unknown signal or two signals and one power on rear most pins, marked "*".
N/C means no connect.
One more thing, verified on rear left pin is N/C next to pin 1, with light shining through the slot board PCB to see if the via is connected carefully looked for buried trace at a via, not there either compared to other locations of buried trace at any via. The photos of PSU I found so far on VCFed for Deskpro M shows previously said 3 pins are connected on the PSU board itself cast more doubts.
PS: via means drilled hole with conductive metal plated through so tracks can make through connection on both sides or to make a track connection at a soldered via.
Here's the semi-complete pinout for Deskpro M line series (386DX, 486 and early Pentium socket 60/66)
This is 24 position connectors with last two positions has metal pins not present, facing front. Pin 1 is towards rear of chassis as "o".
*N/C (?) X 0 pin 1 * (voltage sense or something?)
-5V X X (?) *
GND X X -12V
GND X X GND
GND X X GND
GND X X GND
+5V X X +5V
+5V X X +5V
+5V X X +5V
+5V X X +12V
N/C X X +12V
N/C X X N/C
Great Northern aka Canada.
