First post, by TheAbandonwareGuy
- Oldbie
So I picked up an IBM Model 55SX PS/2 today, and I cannot get it to boot.
Whenever I power it up with a freshly made rf5565A floppy it counts RAM (currently equipped with 4MB), and then displays this error after seeking from floppy:
From what I can tell the errors are as follows:
301 - Keyboard Error (This is correct as none was connected)
161 - Dead CMOS Battery
163 - Configuration Error (resultant from a dead battery)
If I insert a standard DOS bootable disk it displays the same error without the graphical parts, and polls the floppy drive constantly. In either case the light on the Hard Disk module is flashing until it gets to the 163 error, and then on constantly.
Are these machines incapable of booting even from the floppy if the Dallas RTC is dead or should it still be able to boot from the floppy? Pressing F1 in either scenario dumps it into IBM Basic. The floppy disk is quite loud at first, then quiets down. I don't know if thats normal or if the floppy drive is dead. I don't mind spending $10 to get a new RTC battery for it, but if the floppy disc or the HDD is dead the cost likely exceeds the value as I figure I'm looking at a lot of money to get a soundcard for the MCA bus (I figure $100 minimum).
Does this behavior sound normal? I'm not very well versed in PS/2 computers.
