First post, by Xs1nX
Hi,
So I got the Slot 1 CPU and Slot 1 Motherboard today.
Powered it up and CPU and PSU fan spin, Case Fan attached to the Motherboard does not. No video out.
Tried clearing CMOS, Tried a different video card, also tried everything disconnected but video card. And did try some different memory to but all i had was some 66mhz stuff, but again same results overall.
Any suggestions ?
Reply 5 of 46, by Xs1nX
Chaintech 6BTM motherboard here: https://www.ebay.co.uk/itm/254594779337
Intel PII 350MHZ here: https://www.ebay.co.uk/itm/324006550148
PSU,Video and Memory used yesterday on a Socket 7 system, booting fine.
Reply 8 of 46, by Xs1nX
red-ray wrote on 2020-05-22, 14:05:
Get a Diagnostic Tester POST Card and check how far things get
Cant really wait on getting something like that from China due to any returns/refunds needed for ether the CPU or Mobo, normal China post takes a month at the best of times and these are not the best of times.
Reply 12 of 46, by Xs1nX
evasive wrote on 2020-05-22, 14:59:
replaced the CMOS battery?
I see it came with one, you can be sure that is dead or dying (low voltage in-circuit) and can cause symptoms like this.
Replaced it with a known good one from another motherboard(i.e it was keeping settings with no AC fine) and still nothing.
Reply 13 of 46, by Xs1nX
Doornkaat wrote on 2020-05-22, 15:20:
Another idea: Try changing JP8 (Power Failure Recovery) to 2-3 and try turning the PC on using the PSU switch.
This did not work ether, also I double checked the PC100 RAM in a Socket 7 system and it is fine.
So pretty much the only thing I have not tried is another CPU because I simply do not have another Slot 1 CPU here.
Reply 15 of 46, by Xs1nX
austinham wrote on 2020-05-22, 15:45:
cmos battery and jumper?
Tried a different CMOS battery, checked all jumpers are correct.
I have I think done everything I can do and no luck, so given what I have said would my prime suspect be indeed the CPU ?
Reply 17 of 46, by Xs1nX
austinham wrote on 2020-05-22, 16:21:
removed the CPU and see if you get any beeps. My money is on a bad board however.
i dont have a PC speaker also the board was tested before shipping and the CPU was not so I am not sure.
