First post, by gabimor
Hello!
I have some old motherboards, that I received in a bad aesthetical condition.
For motherboards with a little bit of corrosion in the rear panel ports, I have used wet sand and dremel for polishing.
For places which is not reachable by the dremel, I have used cotton swab with polishing compound, which is not efficient as the dremel.
And what about you?
How you deal with corrosion with the rear panel ports?
Thank you!!
